i´m sorry for my bad englsih
espeasy (20231225 CollectionA 4M [ESP8266,ESP32,ESP32-S2/S3/C3]) run at a Wemos D1 mini.
The SHT31 works fine but the Dallas D18B20 doesn´t have a adress or a value.
Both sensors connected on the same pin D2 and the SCL from the SHT31 is connected to the pin D1.
Between 5V and D2 is a 4K7 pullup.
At the I2C Scan i can only find the SHT31.
What is my mistake?
(i cant select pin D2 at the config of the Dallas Sensor is that correct?)
SHT31 with D18B20 doesn´t work
Re: SHT31 with D18B20 doesn´t work
You can't share 1-Wire with I2C using the same pins.
I2C needs 2 pins which are exclusively used for I2C devices.
You can have multiple 1Wire devices on the same 1Wire bus, but not other kinds of devices.
Also you really should not pull up pins to 5V as you likely will destroy other sensors connected to the pin.
But both sensors are I2C Sensors with diffent adress´s!
And for the SHT31 i can select the adress. But i can only took the 0x45, when a took the 0x44 it´s not possible to enable the sensor after submit.
It´s little bit confuse
Ok i have changed the Dallas to Pin D4 and now it works.
Thx
Thx
Users browsing this forum: Bing [Bot] and 1 guest
