pulscount issue on R78
bennybubble
#1 Post by bennybubble » 13 May 2016, 22:19
I'm using a ESP12 with R78 to monitor my power and gas meter.
Power is connected to GPIO-13 and the gas to GPIO-16.
Power is working well and today I added the gas counter hardware, strangely enough the gas counter doesn't work.
The signal arrives at the ESP12 (0 or 5 volt) but it is not counted.
Interesting detail is that when I make it a switch input, the signal is detected by the ESP12 but not when using it as a counter.
https://www.dropbox.com/s/8o0meflrxk4pr ... 2.png?dl=0
Any thoughts ?
-ben
kr0815
Re: pulscount issue on R78
#2 Post by kr0815 » 14 May 2016, 00:38
Are you sure about the 5V ? This will kill the ESP, max 3.3V
bennybubble
#3 Post by bennybubble » 14 May 2016, 17:22
Yes correct, but why does it work with switch input ?
But I will make it 3.3V to see if this solves the problem.
-ben
bennybubble
#4 Post by bennybubble » 14 May 2016, 18:53
Changed it to 3.3 volt, no difference.
Works well with switch input but NOT with counter!
Could it be related to GPIO-16 port ?
-ben
bennybubble
#5 Post by bennybubble » 14 May 2016, 19:43
Moved signal to GPIO-4, problem solved.
Cannot explain, anyone else ?
-ben
dduley
#6 Post by dduley » 14 May 2016, 20:25
There are bugs in the counter plugin. I couldn't get formulas to work
Mickbaer
#7 Post by Mickbaer » 30 May 2016, 14:50
The GPIO16, can not be used for Interrupt driven puls counts.
It is an issues of the ESP8266, see esp data sheet.
