I would like show you my new projects....
Home temperature/humidity sensor and e-ink display whitch use web interface zivyobraz.eu here is possible import data direct to espeasy device - http get
Some new projects
Some new projects
- IMG_3667.jpg (82.18 KiB) Viewed 2272 times
- IMG_3666.jpg (101.45 KiB) Viewed 2272 times
- IMG_3653.jpg (47.11 KiB) Viewed 2272 times
- IMG_3652.jpg (23.6 KiB) Viewed 2272 times
- IMG_3649.jpg (57.66 KiB) Viewed 2272 times
- IMG_3648.jpg (74.82 KiB) Viewed 2272 times
- IMG_3646.jpg (74.5 KiB) Viewed 2272 times
Re: Some new projects
Looks interesting.
Can you give some additional infos to the sensor?
Did you made it yourself or is it a preexisting device one can buy somewhere?
You can buy it from me hehe
I can provide files for PCB or finish PCB and also STL files for 3D print.
For humidity and temperature use SCD41 + for second temp DS18B20.
Device use TPL5110 as main switch. After switch on all ready up, send measuring and switch off, no I have setup 90sec on cca 400sef off.
Numbers from SCD and DS is verry similar and also similar with other thehrometer
It´s quite a long time to be on. I guess it is necessary for the CO2 sensor?
