I'm interested in extracting data from a smart meter.(EasyMeter Q3A / Apator APOX+ (SML))
I've managed to extract some values using a Tasmota solution, I'm not satisfied with the compilation process and other limitations it presents. I would like to transition to using ESP Easy, similar to all my other devices. I am using a ttl Hichi Smartmeter.
For Tasmota, the following points were crucial during compilation and for data extraction:
Is there a way to achieve this using an Olimex ESP32-POE Ethernet Development Board (ESP32-POE)? Has anyone successfully attempted this? Alternatively, I'm open to using a WT32-ETH as I don't have Wi-Fi access in the meter room.#ifndef USE_SCRIPT
#define USE_SCRIPT
#endif
#ifndef USE_SML_M
#define USE_SML_M
#endif
#ifdef USE_RULES
#undef USE_RULES
#endif
and the script:
>D
>B
=>sensor53 r
>M 1
+1,3,s,0,9600,SML
1,77070100010801ff@1000,Verbrauch_Tarif_1,kWh,Verbrauch_T1,7
1,77070100010802ff@1000,Verbrauch_Tarif_2,kWh,Verbrauch_T2,7
1,77070100010800ff@1000,Verbrauch_Summe,kWh,Verbrauch_Summe,7
1,77070100020800ff@1000,Einspeisung_Summe,kWh,Einspeisung_Summe,7
1,=h--
1,77070100240700ff@1,Leistung_L1,W,Watt_L1,2
1,77070100380700ff@1,Leistung_L2,W,Watt_L2,2
1,770701004c0700ff@1,Leistung_L3,W,Watt_L3,2
1,77070100100700ff@1,Leistung_Summe,W,Watt_Summe,2
1,=h--
1,77070100200700ff@1,Spannung_L1,V,Volt_L1,1
1,77070100340700ff@1,Spannung_L2,V,Volt_L2,1
1,77070100480700ff@1,Spannung_L3,V,Volt_L3,1
Your assistance and insights would be greatly appreciated.
