about mega-20240229 ernergy build 82* fail dark-mode option
pwassink
#1 Post by pwassink » 12 Mar 2024, 07:35
Hi guys and girls.
When upgrading an couple of esp 82* to mega-20240229 i've found that somehow the whole web-config part is missing
in the energy -build 4M1 version they falll back to normal and the option web is missing in tools>advanced config menu.
not a showstopper, but please investigate .. :-)
The energy data received from the meter is also corrupt, as far as i can see, Domoticz log entries say :
2024-03-12 07:42:31.659 P1 wifi Electra Gas Water interface: Dismiss incoming - CRC failed
2024-03-12 07:42:32.676 P1 wifi Electra Gas Water interface: Dismiss incoming - CRC failed
2024-03-12 07:42:33.679 P1 wifi Electra Gas Water interface: Dismiss incoming - CRC failed
2024-03-12 07:42:34.553 P1 wifi Electra Gas Water interface: Dismiss incoming - value is not delimited in line "1-0:2.8.2(002"
2024-03-12 07:42:35.548 P1 wifi Electra Gas Water interface: Dismiss incoming - value is not delimited in line "1-0:1.8.2("
2024-03-12 07:42:36.567 P1 wifi Electra Gas Water interface: Dismiss incoming - value is not delimited in line "1-3:0.2.8(5"
2024-03-12 07:42:37.613 P1 wifi Electra Gas Water interface: Dismiss incoming - value is not delimited in line "1-0:22.7.0(00.00"
2024-03-12 07:42:38.643 P1 wifi Electra Gas Water interface: Dismiss incoming - CRC failed
2024-03-12 07:42:39.555 P1 wifi Electra Gas Water interface: Dismiss incoming - value is not delimited in line "1-0:2.8.1(000959."
2024-03-12 07:42:40.674 P1 wifi Electra Gas Water interface: Dismiss incoming - CRC failed
2024-03-12 07:42:41.690 P1 wifi Electra Gas Water interface: Dismiss incoming - CRC failed
2024-03-12 07:42:42.588 P1 wifi Electra Gas Water interface: Dismiss incoming - value is not delimited in line "1-0:2.8.2(002"
2024-03-12 07:42:43.546 P1 wifi Electra Gas Water interface: Dismiss incoming - value is not delimited in line "1-3:0.2.8(5"
2024-03-12 07:42:44.665 P1 wifi Electra Gas Water interface: Dismiss incoming - CRC failed
2024-03-12 07:42:46.617 P1 wifi Electra Gas Water interface: Dismiss incoming - value is not delimited in line "1-0:61.7.0(0"
2024-03-12 07:42:47.559 P1 wifi Electra Gas Water interface: Dismiss incoming - value is not delimited in line "1-0:1.8.1(004545."
Peter
Re: about mega-20240229 ernergy build 82* fail dark-mode option
#2 Post by Ath » 12 Mar 2024, 08:17
No need to investigate ;)
For the Climate builds we've had to activate the 'LIMIT_BUILD_SIZE' compile-time option to be able to fit in all current plugins. This causes the Dark-mode code and css to be excluded from the binary.
pwassink wrote: 12 Mar 2024, 07:35 2024-03-12 07:42:31.659 P1 wifi Electra Gas Water interface: Dismiss incoming - CRC failed
If you set "RX Receive Timeout (mSec)" to 5 msec, the receive errors should be fixed; processing speed has improved at some point, causing the small delays in transmission by the meter to be seen as "I'm done sending", while it's actually not yet complete. This small delay helps in solving that.
