"command unknown" on publish rule?
treii28
#1 Post by treii28 » 03 May 2024, 18:37
I'm new to ESP Easy and have a 1M install (for now) on an ESP-01s relay module that I'm using to turn a small pump on and off.
For some reason, now that I'm adding more MQTT publish info into the rule set, the publish line for when the pump is turned on an offi is returning Command Unknown on the status
On System#Boot Do
  GPIO,0,1
  Publish,"%sysname%/status/flash/freq","%flash_freq%MHz"
  Publish,"%sysname%/status/flash/freq","%flash_size%Bytes"
  Publish,"%sysname%/status/CPU/freq","%cpu_freq%MHz"
  Publish,"%sysname%/status/FS/size","%fs_size%Bytes"
  Publish,"%sysname%/status/FS/free","%fs_free%Bytes"
  TimerSet,2,15
// report time on system waking
On System#Wake Do
  GPIO,0,1
  // NTP time is likely not yet set on first start
  if %unixtime%>0
    Publish,"%sysname%/status/Sleep","%lcltime%:Awake"
  TimerSet,2,15
On Time#Initialized Do
  Publish,"%sysname%/Time/Init","%lcltime%"
  Publish,"%sysname%/Time/Sunrise","%sunrise%AM"
  Publish,"%sysname%/Time/Sunset","%sunset%PM"
On Rules#Timer=1 Do
  GPIO,0,1
  [i]Publish,"%sysname%/Relay/Pump","%lcltime%:Off"[/i]
  Publish,"%sysname%/Power/VCC","%vcc%VDC"
  TimerSet,2,270
On Rules#Timer=2 Do
  // only turn on the pump during daylight hours
  if (%syssec_d%>%s_sunrise%) and (%syssec_d%<%s_sunset%)
    GPIO,0,0
    [i]Publish,"%sysname%/Relay/Pump","%lcltime%:On"[/i]
    TimerSet,1,30
    TimerSet,2,1800
On System#Sleep Do
  Publish,"%sysname%/status/Sleep","%lcltime%:Sleeping"
  GPIO,0,1
It appears to be throwing the error on both the on and off publish commands:
Command unknown: Relay,0,2024-05-03 12:24:58:Pump On
Command unknown: Relay,0,2024-05-03 12:20:28:Pump Off
Command unknown: Relay,0,2024-05-03 12:19:58:Pump On
Re: "command unknown" on publish rule?
#2 Post by TD-er » 03 May 2024, 18:52
Which exact build are you using (filename as reported in the sysinfo page)
Publish is part of MQTT and if you don't have any MQTT controller included in your build, then the publish command isn't present in the build.
ESP01 is extremely limited due to its 1M flash.
#3 Post by Ath » 03 May 2024, 19:08
Your MQTT broker is returning a 'Relay....' command to your unit, when you publish to the Relay topic.
This implies your configuration issue is in the MQTT broker, not on the ESPEasy side. ESPEasy doesn't have a 'relay' command, AFAIK.
treii28
#4 Post by treii28 » 16 May 2024, 18:05
Not sure what the issue was, but i retyped the lines, i swear exactly the same after making changes elsewhere, and it was working again.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 16 guests
