INA219 current/power always -0.00
treii28
#1 Post by treii28 » 20 May 2024, 16:54
I am using a xiao ESP32S3 and wanted to monitor the power coming straight out of the battery going into the 12v->usb buck converter. I get voltage values just fine but current and power are always -0.00. I am not using a 'shunt' as it is only the xiao and a 10W pump connected through the INA219 so at 12v it should be well under 2A max.
Re: INA219 current/power always -0.00
#2 Post by TD-er » 20 May 2024, 18:23
How is the INA219 wired?
Can you describe how it is wired?
I just searched online for some images on how it should be connected.
Found this one which seems the most clear one:
Source
What I notice is that the GND of the load seems to be isolated from the GND of the Arduino.
So I wonder if you can even measure the load of the ESP itself.
I have to read the datasheet thoroughly to make sure.
ekrzychoooo
#3 Post by ekrzychoooo » 04 Jul 2024, 14:32
In the above diagram, there is no control of the input voltage which should be below 26V.
It's easy to damage the input pins.
INA219 ground and loads should be connected.
Users browsing this forum: YandexBot [bot] and 26 guests
