Compiling error
BertM
Compiling error
#1 Post by BertM » 23 May 2016, 18:16
I tried to compile ESPeasy and I get the following error(s)
I have looked @ the wiki and searched the internet, but it seems to be an IDE problem.
Simple programs will load on the ESP..
Help is much appriciated
Bert
tozett
Re: Compiling error
#2 Post by tozett » 23 May 2016, 19:12
which board version for esp do you use 2.0/2.1?
may downgrade ide to 1.6.5 ?
BertM
Re: Compiling error
#3 Post by BertM » 23 May 2016, 19:45
tozett wrote:which board version for esp do you use 2.0/2.1?
Downloaded 1.6.5 and installed esp 2.0 as mentioned in the wiki
Now I get this:
Tried this without succes:
https://github.com/adamvr/arduino-base64
nightshark
Re: Compiling error
#4 Post by nightshark » 23 May 2016, 20:09
I am assuming you moved all of the library files like it says in the Wiki? I had a heck of a time compiling too. I finally uninstalled the Arduino IDE and used the standalone version so my libraries would get pulled correctly.
BertM
Re: Compiling error
#5 Post by BertM » 23 May 2016, 20:18
nightshark wrote:I am assuming you moved all of the library files like it says in the Wiki? I had a heck of a time compiling too. I finally uninstalled the Arduino IDE and used the standalone version so my libraries would get pulled correctly.
Yes I complete uninstalled and installed 1.6.5 again, installed base64.. but still get errors
seems the libaries are not global??
what is the standalone version ? sorry NOOB
costo
Re: Compiling error
#6 Post by costo » 24 May 2016, 01:14
You should download the stable version R78 , the link is at the bottom of this page: http://www.esp8266.nu/index.php/Main_Page
In the zipfile you will find the libraries you need.
After adding these libraries you can compile also the newer versions up to R107
nightshark
Re: Compiling error
#7 Post by nightshark » 24 May 2016, 04:44
I'm new to this myself! It's the big zip file. It says non admin install or just 'Windows' on the Arduino download page. This is assuming you are using Windows. Also try using esp 2.1 I think it's called.
BertM
Re: Compiling error
#8 Post by BertM » 25 May 2016, 17:05
costo wrote:You should download the stable version R78 , the link is at the bottom of this page: http://www.esp8266.nu/index.php/Main_Page
@Costo
Version R78 compiles and uploads nicely, but the version from Github gives the above errors :roll:
costo
Re: Compiling error
#9 Post by costo » 25 May 2016, 21:25
BertM wrote: Downloaded 1.6.5 and installed esp 2.0 as mentioned in the wiki
I guess you need to install ESP Core 2.1.0 when compiling latest ESPEasy from github
tozett
Re: Compiling error
#10 Post by tozett » 26 May 2016, 10:37
also reports for succes with core 2.2
http://www.esp8266.nu/forum/viewtopic.p ... .1.0#p6783
BertM
Re: Compiling error
#11 Post by BertM » 26 May 2016, 12:53
I think you are right: Got even errors with my old sketches, I spent Yesterday evening removing and installing the IDE again and it seenms something was corrupt in the ESP core :?
Will give it an try again this evening.
After a new install of the IDE and ESP Core 2.1.0 the program compiled without one problem.
Thanks for the help!
manjh
Re: Compiling error
#12 Post by manjh » 19 Jul 2016, 16:30
In order to test the new OTGW print, I need to install the latest version of ESPEasy (I have used the flash 78 until now).
So I downloaded from GIT, unzipped and renamed the folder to ESPEasy, and tried to compile.
Got an error message:
ESPEasy.ino:222:22: fatal error: base64.h: No such file or directory
compilation terminated.
Error compiling.
Using Arduino compiler 1.6.5.
What am I doing wrong?
Martinus
Re: Compiling error
#13 Post by Martinus » 19 Jul 2016, 18:00
manjh wrote:In order to test the new OTGW print, I need to install the latest version of ESPEasy (I have used the flash 78 until now).
Error compiling.
You have to change to Arduino ESP core 2.1.0.
Maybe we should update the wiki on this...
manjh
Re: Compiling error
#14 Post by manjh » 19 Jul 2016, 18:15
Error compiling.
Hmmm... I am thinking of this for two types of users:
1. the ones that simply want to flash the software into the MCU units
2, hard core developers that want to make changes to the source code
The second category will probably have no problem setting up the compiler etcetera.
The first category is better off with the bin files, that can be flashed into the hardware.
The role I am playing at this moment (tester) is in the first category... so I am looking for a bin file for R110 or higher. The OTGW manual prescribes it.
Can you help me get that?
manjh
Re: Compiling error
#16 Post by manjh » 19 Jul 2016, 18:25
Great, thanks! :)
DrEmil
Re: Compiling error
#17 Post by DrEmil » 21 Jul 2016, 14:05
I was having the same trouble compiling and tried all the recs on this thread. What finally worked perfectly was to just download the stable image (now at v108), extract, then compile directly from the source (and libraries) included in that image. Worked perfectly the first time on Arduino 1.6.5 (installer) and ESP 2.1.
Hope this helps,
Eric
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 13 guests
