Rules VAR storing during Deepsleep and Coldstart
Rampler
#1 Post by Rampler » 04 Jun 2024, 08:57
Hi Experts,
today i realized that my rule does not work anymore..
On System#Boot Do
 if [VAR#1]=0     //Variables will be set to 0 only on power cycle, the state will be stored as long battery is connected
  timerSet,1,30     //Give us 30 seconds after power cycle in order to logon to gui
 timerSet,2,30      //Deepsleep after 30 seconds if we have problems
EndOn
On System#Sleep Do
let,1,1              //set Reboot-Deepsleep
EndOn
// VAR#1:  Power on        => 0, Reboot/Deepsleep  => 1
On Rules#Timer=1  Do  //Call only on power cycle
 deepsleep,120
EndOn
On Rules#Timer=2  Do  //Init Time
 TaskRun,2                   //Start DHT22
 TaskRun,1                  //Start Voltage
EndOn
On MQTT#Connected Do       //When broker is connected
 timerSet,2,3                          //Init Time
EndOn
On DHT22#Humidity Do
logentry,"VAR#1 on DHT22 EVENT: [VAR#1]"
 publish /Holzkeller_Klima/Humidity,[DHT22#Humidity]
 publish /Holzkeller_Klima/Temperature,[DHT22#Temperature]
 publish /Holzkeller_Klima/Voltage,[Voltage#Voltage]
  if [VAR#1]=1    //Run only when already in deepsleep mode, first power cycle was finished
    deepsleep,120
EndOn
In the past time, var#1 was stored/remembered during a deepsleep. Var#1 was only deleted during a cold start.
Now VAR#1 is deleted in both scenarios, cold start and deepsleep.
Can i control this behavior ?
regards
Klaus
Re: Rules VAR storing during Deepsleep and Coldstart
#2 Post by TD-er » 04 Jun 2024, 10:34
Var values were never kept/restored during deepsleep.
Storing data in dummy tasks will be kept in RTC memory and restored on boot. (as long as the device remained powered)
Users browsing this forum: Google [Bot] and 18 guests
