INA219 Values - Plugin Bug ?
Affinite
#1 Post by Affinite » 26 Jan 2021, 14:14
Hi guys
Im trying to output only Current values from an INA219 Voltage/Current/Power sensor.
The problem is that, in the plugin, when I select "Current" in the Measurement Type box I continue to get Voltage, Current and Power values sent out.
Is this a bug in the plugin or finger trouble on my part?
PS - I know I could just ignore the unwanted data but I actually want to send just the TaskName and not the Valname over MQTT so as to format the MQTT to mimic SignalK keys
Re: INA219 Values - Plugin Bug ?
#2 Post by Ath » 26 Jan 2021, 15:25
The omission is probably that the value count isn't reset to 1, from 3, if only 1 value should be sent.
Can you report this on the Github issue tracker as an issue so it won't get lost?
Affinite
#3 Post by Affinite » 28 Jan 2021, 21:00
Logged in Github
#4 Post by Ath » 28 Jan 2021, 22:22
Yes, I saw that, so I cross-referenced issue #3841 back to this forum topic ;)
(I'm using a different handle on Github 8-))
#5 Post by Ath » 19 Jul 2024, 22:31
@Affinite I've corrected this issue and you can test by downloading the build from Github, over here, TIA :)
