Plugin for zero cross detection?
DMeekelenkamp
#1 Post by DMeekelenkamp » 03 Dec 2015, 17:17
Would it be possible to detect zero cross from the mains so we can dim 220v lighting with the esp module?
Or would this be more a task for the connexio?
chunter1
Re: Plugin for zero cross detection?
#2 Post by chunter1 » 26 Jan 2016, 14:49
I would appreciate a solution for this too very much.
@DMeekelenkamp:
Do you already have a particular dimmer circuit/modul in mind?
Would be great to have a simple dimmer module with 2 connections (zero-crossing & turn-off) for the ESPEasy. (could not find one on aliexpress/ebay yet)
costo
#3 Post by costo » 26 Jan 2016, 18:02
DMeekelenkamp wrote:Would it be possible to detect zero cross from the mains so we can dim 220v lighting with the esp module?
I do not believe this can be done on the ESP.
You would need a permanent connection to the mains while a powersupply is not a integrated part of a ESPEasy module.
A lot of people will feed the circuit from a USB-like powersource or even a battery with sleep mode.
DMeekelenkamp
#4 Post by DMeekelenkamp » 28 May 2016, 20:39
Found this on the Internet:
https://youtu.be/QKkx3UjTXco
A zero cross detection 0-3v mains dimmer can be used with the esp8266 maybe worth a try.
https://www.tindie.com/products/nEXT_EV ... r-mpdmv41/
