a simple help on syntax
giorgino
#1 Post by giorgino » 21 Oct 2024, 21:53
an easy question...
working with floating number, I need to pass integer value to this
NEXTION,page2.n0.val=6
and I obtain 6
and when I have 2 integer:
NEXTION,page2.n0.val=6+2
obatain 8
then I write
NEXTION,page2.n0.val=7.2+2
and doesn't work
...I know, it' s so easy...
Re: a simple help on syntax
#2 Post by TD-er » 21 Oct 2024, 22:07
I guess you're generating these in rules?
If so, then you can use the let command to compute an intermediate value and store it in a variable.
let,1,7.2+2 // Store in variable #1
NEXTION,page2.n0.val=[var#1]
giorgino
#3 Post by giorgino » 21 Oct 2024, 22:22
ah , ok
so, no direct in the
#4 Post by TD-er » 21 Oct 2024, 22:32
The inline-parsing isn't working like that.
Only with the '=' on the first position when parsing numerical values, the parser will try to evaluate the formula.
However this may give some unexpected results, so best to use "let" to evaluate calculations.
giorgino
#5 Post by giorgino » 21 Oct 2024, 23:01
ok, good!
now, I need to send integer, so my syntax become:
let,1,round(([MQTbox#dm_vol]-9000)*0.03) // Store in variable #1 l'angolo di riferimento dei volt batteria (dm_volt)
NEXTION,page1.z1.val=[var#1]
but if I need to truncate my floating 12.347 to 12.34 can I use something like ROUND(x,2) ?
#6 Post by Ath » 21 Oct 2024, 23:16
You'll need a transformation, as documented here
So your case could be like
let,1,([MQTbox#dm_vol]-9000)*0.03 // Store in variable #1 l'angolo di riferimento dei volt batteria (dm_volt)
NEXTION,page1.z1.val=[var#1#d1.2]
The 'd' is a Decimals transformation, with spaces prefix if needed ('D' is with zeros prefixed)
the '1' is a minimum of 1 digits before the decimal point (you can set to 0 if desired)
the '.2' is having 2 decimals after the decimal point, value is rounded.
The value is stored in a floating point format, so no information about the number of decimals is stored, that's to be specified when 'presenting' the value, hence the formatting and justification options are included in the variable retrieval.
giorgino
#7 Post by giorgino » 21 Oct 2024, 23:45
B-)
GREAT!!
