Problem with Display - NeoPixel Matrix
Milan
#1 Post by Milan » 28 Nov 2024, 10:01
I have a problem with the functionality of two of these modules at the same time. Either displays one or the other , but not at the same time.
Has anyone encountered this?
My board is ESP32-S3 N16R8, build- ESP_Easy_mega_20241025_max_ESP32s3_16M8M_LittleFS_CDC_ETH
On the previous build mega-20240822 that didn't work either. But the same configuration on ESP8266 is running without problem.
Thanks a lot.
Re: Problem with Display - NeoPixel Matrix
#2 Post by TD-er » 28 Nov 2024, 10:06
On ESP32-xx it makes perfect sense why it doesn't work as the current implementation of the addressable LEDs is using RMT.
However yesterday the Tasmota team released a complete rewrite of the addressable LED library which allows for switching between RMT/I2S/SPI. (I have been part of the discussion involved in this rewrite)
So Ton is already looking into what needs to be done to make this also work for ESPEasy.
S-Hadinger did try to make it as generic as possible, so it should not require a complete rewrite to make it work on ESPEasy :)
TL;DR
We're aware of this limitation and already working on it :)
Milan
#3 Post by Milan » 28 Nov 2024, 10:09
Thank you very much for the explanation.
