Quinetic Devices and Protocol
AJTaylor79
#1 Post by AJTaylor79 » 13 Nov 2024, 12:27
I own a number of devices that are manufactured under the Quinetic brand https://www.quinetic.co.uk
I was hoping that the RFLink firmware would pick up the Raw protocol that they use, unfortunately I am not seeing anything incoming while under debug.
Someone has gone ahead and reversed engineered the Quinetic protocol.
More details below;
https://www.youtube.com/watch?v=tz_F4Tjhap0
https://github.com/camerongray1515/Kinetic2MQTT
My questions are as follows;
Should I see any Raw code coming in?
Will I be able to get it working in Home Assistant
bidrohini
Re: Quinetic Devices and Protocol
#2 Post by bidrohini » 30 Nov 2024, 18:43
If you see no raw data, it's possible that RFLink does not yet have support for the Quinetic protocol. There can be a mismatch in the frequency or modulation method used by Quinetic devices and what RFLink is currently configured to detect.
