Display - HT16K33 commands
user1234
#1 Post by user1234 » 23 Dec 2024, 16:31
Where i i can find command or samples for Display - HT16K33 ?
at the Info site:
https://espeasy.readthedocs.io/en/lates ... /P057.html
is nothing .
i found only a topic from a user with this " example: MNUM,CLEAR,3,3,0,9,5 will display 33:95) " ?????
Re: Display - HT16K33 commands
#2 Post by Ath » 23 Dec 2024, 16:47
Ah, documentation on that plugin is a bit sparse. I'll see if I can improve that a bit, soon.
The source code is of course the best documentation, but not for all users very readable :lol:
A short extract, straight from the source code file:
// List of commands:
// (1) M,<param>,<param>,<param>, ... with decimal values
// (2) MX,<param>,<param>,<param>, ... with hexadecimal values
// (3) MNUM,<param>,<param>,<param>, ... with decimal values for 7-segment displays
// (4) MPRINT,<text> with decimal values for 7-segment displays
// (5) MBR,<0-15> set display brightness, between 0 and 15
// List of M* params:
// (a) <value>
// Writes a decimal / hexadecimal (0...0xFFFF) values to actual segment starting with 0
// (b) <seg>=<value>
// Writes a decimal / hexadecimal (0...0xFFFF) values to given segment (0...7)
// (c) "CLEAR"
// Set all LEDs to 0.
// (d) "TEST"
// Set test pattern to LED buffer.
// (e) "LOG"
// Print LED buffer to log output.
// Examples:
// MX,AA,55,AA,55,AA,55,AA,55 Set chess pattern to LED buffer
// MNUM,CLEAR,1,0 Clear the LED buffer and then set 0x06 to 1st segment and 0x3F to 2nd segment
user1234
#3 Post by user1234 » 23 Dec 2024, 18:50
ok, thanks, I will try it.
And how i can select/adress the different devices (Dot 8x8 Matrix digits) with different I2C Adress ?
http://192.168.5.203/control?cmd=MX,AA, ... A,55,AA,55
#4 Post by Ath » 23 Dec 2024, 19:31
user1234 wrote: 23 Dec 2024, 18:50 And how i can select/adress the different devices (Dot 8x8 Matrix digits) with different I2C Adress ?
You can prefix the command with a taskname and a period/dot, like this:
http://192.168.5.203/control?cmd=display1.MX,AA,55,AA,55,AA,55,AA,55
