ESP-01S with W25Q128FVSG
cccp79
#1 Post by cccp79 » 01 Feb 2025, 09:52
Hi! I replaced the flash chip on the ESP-01S board with a W25Q128FVSG, and so far it has only been identified as 16M. Can you tell me how to redefine it to the maximum possible memory, like 32M or more?
Снимок экрана от 2025-02-01 11-51-47.png (96.56 KiB) Viewed 1802 times
Снимок экрана от 2025-02-01 11-49-11.png (429.56 KiB) Viewed 1802 times
chromo23
Re: ESP-01S with W25Q128FVSG
#2 Post by chromo23 » 01 Feb 2025, 12:07
cccp79 wrote: 01 Feb 2025, 09:52 and so far it has only been identified as 16M
It's a 128MBit chip. So the maximum is 16MByte.
#3 Post by TD-er » 01 Feb 2025, 12:08
I am not sure if the ESP8266 is capable of addressing flash > 16MB.
The SPI flash access is done at quite a low level and if there isn't support for larger chips in the SDK/ROM, then it will be too much work to add support for it on ESP8266 platforms.
Also the detected flash size is done using a bitshift based on the reported module type by the flash, so unless it is hard-coded to be limited to 16M, it should detect the true size as reported by the flash.
cccp79
#4 Post by cccp79 » 01 Feb 2025, 12:23
Did I understand correctly that 128Mbit is 16M maximum possible value? Well, for this chip it is quite so good result. I'am happy!)
#5 Post by Ath » 01 Feb 2025, 14:33
AFAICS, the ESP8266 doesn't support flash sizes > 16MB (128 MBit), see this Espressif documentation page
#6 Post by TD-er » 01 Feb 2025, 16:26
cccp79 wrote: 01 Feb 2025, 12:23 Did I understand correctly that 128Mbit is 16M maximum possible value? Well, for this chip it is quite so good result. I'am happy!)
128 Mbit is (128 / 8 = ) 16 MByte.
So the detection is correct :)
Users browsing this forum: Semrush [Bot] and 19 guests
