Missing "Notifications" tab in Custom build
iz8mbw
#1 Post by iz8mbw » 14 Oct 2023, 07:55
Hello.
I have created some Custom build by edit "Custom.h" in order to have a bin with all Plugins I need but I was not able to have the "Notifications" tab in the Web interface.
Both
#define USES_N001   // Email
#define USES_N002   // Buzzer
are enabled.
What I miss?
Re: Missing "Notifications" tab in Custom build
#2 Post by Ath » 14 Oct 2023, 10:45
You will have to disable the line with '#define NOTIFIER_SET_NONE', or possibly replace with '#define NOTIFIER_SET_STABLE' (test first with commenting the define, if that doesn't work as intended, add the other define)
iz8mbw
#3 Post by iz8mbw » 14 Oct 2023, 19:48
Thanks, it works!
damiak
#4 Post by damiak » 03 Apr 2024, 15:42
How in my custom build do more items in notification because there are only 3?
What values to edit when creating custom build?
#5 Post by TD-er » 03 Apr 2024, 19:24
Problem with increasing the max number of notifications is that it can render your settings files incompatible with other builds.
See the NOTIFICATION_MAX in src/CustomBuild/ESPEasyLimits.h file
N.B. increasing this has never been tested, so not sure if you may run in other issues.
damiak
#6 Post by damiak » 04 Apr 2024, 00:36
Ok I'll check and let you know if the number of items has changed
#7 Post by Ath » 04 Apr 2024, 08:06
Well, the tech limit, without completely breaking the settings file out of its boundaries, is 4 notifiers, but changing it from 3 to 4 will already fail compilation, because of compile-time checks that really need investigation before changing and thorough testing afterwards.
Maybe you can explain why you need more than 3 Notification plugins?
damiak
#8 Post by damiak » 04 Apr 2024, 23:36
I have a mail server in the local network on Synology and I would like to send different notifications depending on which button I press or which GPIO is activated and then I check it when I get home. I'm just learning.
#9 Post by Ath » 06 Apr 2024, 22:37
Hi @damiak
I've opened PR #5026 to add support for a user-defined subject when using the Notify command, like:
Notify,1,'Custom message content','My own subject'
Downloads available from this GH Actions run (A free Github account is required to be able to download)
This should resolve the need for multiple Notifications configured.
NB: I only added the subject part, as the user defined message content was already available, but not documented :shock: so I also updated the documentation ;)
damiak
#10 Post by damiak » 07 Apr 2024, 15:04
Thank you for your help
#11 Post by Ath » 01 May 2024, 23:20
@damiak The PR has been merged, and will be in the next ESPEasy release.
damiak
#12 Post by damiak » 13 Feb 2025, 17:46
I recently bought an esp32c3, I have a project in which I send email notifications when I have the appropriate status on GPIO to my own server in the local network on synology and I do it without ssl, I wanted to transfer it to esp32 but the notifications do not come there because there is probably only ssl and I cannot set the synology mail station to go over ssl.
The question is, can I disable ssl mail when compiling custom firmware and how?
#13 Post by TD-er » 13 Feb 2025, 18:01
That issue has recently been solved: https://github.com/letscontrolit/ESPEasy/pull/5238
You could fetch one of the latest builds from the GitHub Actions build, like this one here: https://github.com/letscontrolit/ESPEas ... 3229648014
Or if you need your own custom build, the fixes for sending mail without SSL are already merged, so you could use the latest code from the 'mega' branch.
damiak
#14 Post by damiak » 13 Feb 2025, 18:10
Thank you,
I will use the ready one because compilation is not always successful for me.
Do I have to set something differently or is it like it used to be on 8266 without ssl? I use port 25
#15 Post by TD-er » 13 Feb 2025, 18:21
It should be as simple as just setting the port to 25.
Please let us know if it is working as it should.
damiak
#16 Post by damiak » 13 Feb 2025, 23:52
Now everything is ok, thank you.
#17 Post by TD-er » 14 Feb 2025, 01:11
Great!
Thanks for the feedback.
Users browsing this forum: Ahrefs [Bot] and 14 guests
