Hallo,
Back again. Still very satisfied with this software for reading already 5 Eastron meters through modbus.. But since a week there were troubles with the 8266-board. High load (99.86), slow, sometimes no ping.
Long story short: decided to replace the 8266 to an ESP32-C3 which I had as a spare.
Board was flashed with Build: ESP_Easy_mega_20240419_custom_ESP32c3_4M316k_LittleFS_CDC_ETH Apr 19 2024 and worked out of the box...
Now my question(s):
I tried to update by OTA to the latest build ESP_Easy_mega_20241222_energy_ESP32c3_4M316k_LittleFS_CDC_ETH.bin but I did not succeed. The update did not end with any failure or error... After waiting for at least 10 minutes I do an cold reboot and than I read the same version in the bottom of the screen...
That makes it maybe difficult for the next step:
I want to swap from the ethernet to WIFI, because of lack of ports on the switch in that area.. For now I pulled a plug out to get the ESP working. But the wireless router is 2 feet away..
So the next quistion:
Is this version oké for a change in configuration to WIFI? In menu Hardware I can chose as Preferred network medium: WIFI and there is need for a reboot. But what is next?? Does it pick up the settings from menu Config straight away? I cannot find info how to configure in
https://espeasy.readthedocs.io/en/lates ... l#esp32-s3
Lots of doublts because there is another build: ESP_Easy_mega_20241222_energy_ESP32c3_4M316k_CDC.bin too. Maybe I need that version for my needs? What is the difference between those versions?
Any advice or help appreciated.
Thnx in advance.
