Before I post it, I just want to confirm that sensitive info isn't in the config.dat file.Would you mind sending me the config.dat of the attic device.
All the sensitive data should be in the security.dat as far as I know.
Good news indeed, so the config.dat is not necessary anymore.
Are the 36h already over?
I just uploaded a newer version of easyfetch (20250505/1) addressing this issue.
Yes it was. I also added a check that requests do not start to overlap and keep piling up...
Hmmmm.. that's interesting since the charts have nothing to do with easyfetch accessing ESPEasy.
Reset Reason: CPU0: Software reset CPU CPU1: Software reset CPUIn the info section of the /tools tab you can find the reboot reason. Would be nice to know and maybe helps to find out what's happening...
Without EasyFetch Charting:How much space is left on the file system?
Users browsing this forum: Amazon [Bot] and 21 guests
