My temperature sensor is not getting decoded with the new R40 firmware, it was working fine in the previous versions.
10;version;
20;01;VER=1.1;REV=37;BUILD=05;
10;rfdebug=on;
20;02;RFDEBUG=ON;
20;03;DEBUG;Pulses=96;Pulses(uSec)=480,930,390,930,390,930,390,930,390,930,390,930,390,930,390,930,1380,930,390,930,1380,930,1380,930,1380,930,390,930,1380,930,390,930,1380,930,390,930,1380,930,390,930,1380,930,1380,930,1380,930,1380,930,1380,930,390,930,1380,930,1380,930,390,930,1380,930,1380,930,390,930,390,930,390,930,390,930,390,930,390,930,390,930,390,930,390,930,390,930,390,930,1380,930,1380,930,1380,930,390,930,1380,930,390,6990;
20;04;FineOffset;ID=0455;TEMP=0049;
20;05;DEBUG;Pulses=96;Pulses(uSec)=480,930,390,930,390,930,390,930,390,930,390,930,390,930,390,930,1380,930,390,930,1380,930,1380,930,1380,930,390,930,1380,930,390,930,1380,930,390,930,1380,930,390,930,1380,930,1380,930,1380,930,1380,930,1380,930,390,930,1380,930,1380,930,390,930,1380,930,1380,930,390,930,390,930,390,930,390,930,390,930,390,930,390,930,390,930,390,930,390,930,390,930,1380,930,1380,930,1380,930,390,930,1380,930,390,6990;
20;06;FineOffset;ID=0455;TEMP=0049;
20;07;DEBUG;Pulses=96;Pulses(uSec)=480,930,390,930,390,930,390,930,390,930,390,930,390,930,390,930,1380,930,390,930,1380,930,1380,930,1380,930,390,930,1380,930,390,930,1380,930,390,930,1380,930,390,930,1380,930,1380,930,1380,930,1380,930,1380,930,390,930,1380,930,1380,930,390,930,1380,930,1380,930,390,930,390,930,390,930,390,930,390,930,390,930,390,930,390,930,390,930,390,930,390,930,1380,930,1380,930,1380,930,390,930,1380,930,390,6990;
20;08;FineOffset;ID=0455;TEMP=0049;
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R40;
10;version;
20;01;VER=1.1;REV=40;BUILD=08;
10;rfdebug=on;
20;02;RFDEBUG=ON;
20;04;DEBUG;Pulses=96;Pulses(uSec)=480,930,390,930,390,930,390,930,390,930,390,930,390,930,390,930,1380,930,390,930,1380,930,1350,930,1380,930,390,930,1380,930,390,930,1380,930,390,930,1380,930,390,930,1350,930,1380,930,1380,930,1380,930,1380,930,390,930,1380,930,1380,930,390,930,1380,930,1380,930,390,930,390,930,390,930,390,930,390,930,390,930,390,930,390,930,390,930,390,930,390,930,1380,930,1380,930,1380,930,390,930,1380,930,390,6990;
20;06;DEBUG;Pulses=96;Pulses(uSec)=480,930,390,930,390,930,390,930,390,930,390,930,390,930,390,930,1380,930,390,930,1380,930,1380,930,1380,930,390,930,1380,930,390,930,1380,930,390,930,1380,930,390,930,1380,930,1380,930,1380,930,1380,930,1380,930,390,930,1380,930,1380,930,390,930,1380,930,1380,930,390,930,390,930,390,930,390,930,390,930,390,930,390,930,390,930,390,930,390,930,390,930,1380,930,1350,930,1380,930,390,930,1380,930,390,6990;
Regards,
Søren
Solved: FineOffset
Re: FineOffset
Thanks for reporting. We will look into it as soon as possible.
Re: FineOffset
This should work correctly with rev 42.
