Problem/Bug - Switch with 0 delay is not sending data on boot
theone
#1 Post by theone » 24 Jun 2016, 10:05
Using R107.
I have setup a switch device (pushbutton) and requested to "Send Boot state".
The delay is set to 0 as I only want the state to be sent when it changes.
To test:
* I pressed the pushbutton so Domoticz virtual device is showing ON - OK.
* ESPEASY is showing the pushbutton as "1" in the ESPeasy web interface - OK
* Then I reset my ESP8266 board and it is showing the pushbutton as "0" in the ESPeasy web interface - OK
* But Domoticz is still showing the virtual device as ON - NOT OK !!!
from this I assume it is not sending the state upon boot as it should.
