Can somebody please explain how to upload something to the ESPEasyPluginPlayground on Github.
I have a plugin or two I'd like to contribute for consideration/comments but there doesn't seem to be upload access to the Playground.
N
Re: ESPEasyPluginPlayground
Please provide your github account name and I will add you to the list of contributors with write access.
Hi Martinus
Github account name is the same as used on this forum - namirda
Your account has been added to the playground repo. You should be able to upload using the website or use the github tools to clone/sync local repo's...
hi,
i dont wanted to open another topic..so i add my wish here...
i looked up the playground-plugins for some interesting plugins.
the playground growed alot, it would be advisable somehow to have a minimum explantion for each plugin,
also maybe a weblink/email to the developer.
i suggest to put this _into_ the source-header. so there is only one place for this.
also there is no issue-section or version-informaiton (on github) for the playground-plugins.
i think it is up to the dev, if this could be a standard template to structure the plugins also for some _normal_ user?
would make this more attractive to try outs by normal users, i think.
