[SLOVED] issues on ESP12
Tjeerd
#1 Post by Tjeerd » 23 Jul 2016, 23:37
Hello all,
Afther i have uses succesfully a few sonoffs whit an ESP inside i wanted to build something on my own so i bought some ESP12 F modules.
Afther a long struggle i managed to flash 2 of the (havent tryed the 3th yet), only i have a strange issue.
I have connected the following:
VCC ----> 5v (on 3.3 nothing happend...)
GND ----> Ground
CH_PD ----> HIGH (3.3V)
GPIO2 ----> HIGH (3.3V)
GPIO15 ----> LOW (GND)
GPIO0 ----> HIGH (3.3V) (flashed it whit GND
And i have still the RX and TX connected
As i wrote the flash went ok, and i briefly made contact whit the reset and the bleu led on the esp flashed so the ESP would restart and i wild get the accespoint to connect whit.
when the accespoint dint came up i set GPIO0 to 3.3v and i reconnected the power.
I do not see anything happen and i can not connect whit the serial connection.
does anyone have an idea of what im doing wrong? and could anyone help me to set up the accespoint?
ps. i flashed 108 1024MB in the ESP
Tjeerd
Re: issues on ESP12
#2 Post by Tjeerd » 24 Jul 2016, 09:13
Apparently is mandetory to have a pull up resistor.
I placed a 10k resistor beween v3 and gpoi0 and evrything started working.
its not stabel yet but i geass thats a power isseu
dduley
Re: issues on ESP12
#3 Post by dduley » 24 Jul 2016, 17:39
Tjeerd wrote:Apparently is mandetory to have a pull up resistor.
Hi Tjeerd,
Its good you got it working!
I am concerned about VCC=5v though. These parts are 3.3v only unless you are using somthing like a NodeMCU module that has an on board regulator.
Dave
Tjeerd
Re: [SLOVED] issues on ESP12
#4 Post by Tjeerd » 26 Jul 2016, 13:18
Hello Dave,
Thanks for sharing your concerns.
I only installed the device and im not using it yet. I will messure the volt values this afthernoon to see how much v the 3.3v realy is and the same for the 5v.
I tought that its odd that it only worked on 5v (i have tested whit 3 diverent power supplies on 3) maybe my 5 to 3.3v stepdown isnt that good.
Regards,
Tjeerd
Tjeerd
#5 Post by Tjeerd » 27 Jul 2016, 23:37
There was an extra GPIO pin connected to the 3.3v. that made the esp not come online on 3.3v. i removed the GPIO pin and now its working as it should be on 3.3v
Thanks again.
dduley
#6 Post by dduley » 28 Jul 2016, 21:13
Tjeerd wrote:There was an extra GPIO pin connected to the 3.3v. that made the esp not come online on 3.3v. i removed the GPIO pin and now its working as it should be on 3.3v
Thanks again.
Good News!
Users browsing this forum: Bing [Bot] and 16 guests
