ESPEasy compilation FW R119
piokuc
#1 Post by piokuc » 10 Aug 2016, 08:45
I try compile soft version R118 or R119 for Espeasy and i have a problem and compilation is not finished:
Arduino:1.6.9 (Windows 10), Płytka:"NodeMCU 1.0 (ESP-12E Module), 80 MHz, 115200, 4M (3M SPIFFS)"
ESPEasy:253: error: no matching function for call to 'PubSubClient::PubSubClient(WiFiClient&)'
PubSubClient MQTTclient(mqtt);
C:\Users\pkuchciak\Desktop\ESPEasy_R118\Source\ESPEasy\ESPEasy.ino:253:29: note: candidates are:
In file included from C:\Users\pkuchciak\Desktop\ESPEasy_R118\Source\ESPEasy\ESPEasy.ino:220:0:
C:\Users\pkuchciak\Desktop\arduino-1.6.9-windows\arduino-1.6.9\libraries\pubsubclient\src/PubSubClient.h:47:4: note: PubSubClient::PubSubClient(String, uint16_t)
PubSubClient(String hostname, uint16_t port = 1883);
C:\Users\pkuchciak\Desktop\arduino-1.6.9-windows\arduino-1.6.9\libraries\pubsubclient\src/PubSubClient.h:47:4: note: no known conversion for argument 1 from 'WiFiClient' to 'String'
C:\Users\pkuchciak\Desktop\arduino-1.6.9-windows\arduino-1.6.9\libraries\pubsubclient\src/PubSubClient.h:46:4: note: PubSubClient::PubSubClient(IPAddress&, uint16_t)
PubSubClient(IPAddress &ip, uint16_t port = 1883);
C:\Users\pkuchciak\Desktop\arduino-1.6.9-windows\arduino-1.6.9\libraries\pubsubclient\src/PubSubClient.h:46:4: note: no known conversion for argument 1 from 'WiFiClient' to 'IPAddress&'
C:\Users\pkuchciak\Desktop\arduino-1.6.9-windows\arduino-1.6.9\libraries\pubsubclient\src/PubSubClient.h:43:4: note: PubSubClient::PubSubClient()
PubSubClient();
C:\Users\pkuchciak\Desktop\arduino-1.6.9-windows\arduino-1.6.9\libraries\pubsubclient\src/PubSubClient.h:43:4: note: candidate expects 0 arguments, 1 provided
C:\Users\pkuchciak\Desktop\arduino-1.6.9-windows\arduino-1.6.9\libraries\pubsubclient\src/PubSubClient.h:16:7: note: PubSubClient::PubSubClient(const PubSubClient&)
class PubSubClient {
C:\Users\pkuchciak\Desktop\arduino-1.6.9-windows\arduino-1.6.9\libraries\pubsubclient\src/PubSubClient.h:16:7: note: no known conversion for argument 1 from 'WiFiClient' to 'const PubSubClient&'
C:\Users\pkuchciak\Desktop\arduino-1.6.9-windows\arduino-1.6.9\libraries\pubsubclient\src/PubSubClient.h:16:7: note: PubSubClient::PubSubClient(PubSubClient&&)
C:\Users\pkuchciak\Desktop\arduino-1.6.9-windows\arduino-1.6.9\libraries\pubsubclient\src/PubSubClient.h:16:7: note: no known conversion for argument 1 from 'WiFiClient' to 'PubSubClient&&'
C:\Users\pkuchciak\Desktop\ESPEasy_R118\Source\ESPEasy\Controller.ino: In function 'void MQTTConnect()':
Controller:73: error: 'class PubSubClient' has no member named 'setServer'
MQTTclient.setServer(MQTTBrokerIP, Settings.ControllerPort);
Controller:74: error: 'class PubSubClient' has no member named 'setCallback'
MQTTclient.setCallback(callback);
Controller:96: error: no matching function for call to 'PubSubClient::connect(const char*, char [26], char [64], const char*, int, int, const char [16])'
MQTTresult = MQTTclient.connect(clientid.c_str(), SecuritySettings.ControllerUser, SecuritySettings.ControllerPassword, LWTTopic.c_str(), 0, 0, "Connection Lost");
C:\Users\pkuchciak\Desktop\ESPEasy_R118\Source\ESPEasy\Controller.ino:96:168: note: candidates are:
C:\Users\pkuchciak\Desktop\arduino-1.6.9-windows\arduino-1.6.9\libraries\pubsubclient\src/PubSubClient.h:62:9: note: bool PubSubClient::connect(String)
bool connect(String id);
C:\Users\pkuchciak\Desktop\arduino-1.6.9-windows\arduino-1.6.9\libraries\pubsubclient\src/PubSubClient.h:62:9: note: candidate expects 1 argument, 7 provided
C:\Users\pkuchciak\Desktop\arduino-1.6.9-windows\arduino-1.6.9\libraries\pubsubclient\src/PubSubClient.h:65:9: note: bool PubSubClient::connect(String, String, uint8_t, bool, String)
bool connect(String id, String willTopic, uint8_t willQos, bool willRetain, String willMessage);
C:\Users\pkuchciak\Desktop\arduino-1.6.9-windows\arduino-1.6.9\libraries\pubsubclient\src/PubSubClient.h:65:9: note: candidate expects 5 arguments, 7 provided
C:\Users\pkuchciak\Desktop\arduino-1.6.9-windows\arduino-1.6.9\libraries\pubsubclient\src/PubSubClient.h:101:9: note: bool PubSubClient::connect(MQTT::Connect&)
bool connect(MQTT::Connect &conn);
C:\Users\pkuchciak\Desktop\arduino-1.6.9-windows\arduino-1.6.9\libraries\pubsubclient\src/PubSubClient.h:101:9: note: candidate expects 1 argument, 7 provided
exit status 1
Ten raport powinien zawierać więcej informacji jeśli w
File -> Preferencje zostanie włączona opcja "Pokaż
szczegółowe informacje podczas kompilacji"
But when compile R108 it works all OK and generate for me file ok.
Please help me...
Martinus
Re: ESPEasy compilation FW R119
#2 Post by Martinus » 10 Aug 2016, 09:34
piokuc wrote:Hi
PubSubClient();
exit status 1
Please help me...
Update your pubsub library to version 2.6 and it should work.
piokuc
#3 Post by piokuc » 10 Aug 2016, 09:50
Can you help me from where i can cownload and update this pubsub library ?
Ok i found it:
https://github.com/knolleary/pubsubclie ... s/tag/v2.6 download and replace and ok i compile file bin.
But i have a question. When i no set configuration in ESPeasy.ino like ip, ip domoticz etc) and compile file and then write to my nodeMCU which now working with setup ip, ip domoticz and etc , settings will be reset after update firmware ?
JR01
#4 Post by JR01 » 10 Aug 2016, 12:11
Did you update your pubs client on Arduino to version 2.6 ?
Had the same, got fixed after I did that.
(And the latest version of boards manager, think 2.3)
piokuc
#5 Post by piokuc » 10 Aug 2016, 12:15
Yes i update pubsubclient to 2.6 version from link which i send i previous post.
But when i compile firmware without custom settings( default) and now update to my nodeMCU with configuring ip and etc , my setting in nodeMCU will be erase and replace with default ?
Martinus
#6 Post by Martinus » 10 Aug 2016, 12:40
piokuc wrote:Yes i update pubsubclient to 2.6 version from link which i send i previous post.
If you change the defaults in the source code, these values will only be used in case you flash onto a new module (without any previous settings) or if you explicitly erase the configured settings with the 'reset' command.
So upgrading to a newer build should normally not affect your settings.
piokuc
#7 Post by piokuc » 10 Aug 2016, 12:49
Thanks for help.
Can you tell me also how reset my nodeMCU to default settings ? How send command "Reset" ?
JR01
#8 Post by JR01 » 10 Aug 2016, 21:25
Several ways: if you are able to connect with a serial interface to ESP using a FDTI, several commands below. Type into serial interface, I have a Mac, use CoolTerm. Command = Reset on serial command. else use esptool.
The following commands can be used by the esp easy.
- Delay Set the update interval of your attached devices. "Delay 10" means new values are being sent to your controller every 10 seconds.
- Debug Set the debug level. 1: Error 2: Info 3: Debug 4: Debug more. "Debug 4" sets the debug level to debug_more.
- IP Set a static ip adres.
- WifiSSID Set the SSID of your homenetwork. "WifiSSID yournetworkname"
- WifiKey Set the WPA key of your homenetwork "WifiKey yoursecretkey"
- WifiAPKey Set the spa key of this esp unit. This key needs to be used by clients when they want to connect in AP modus.
- WifiScan Scan for active wifi networks. This can be used to test if your wifi is recognized and to verify whether the wifi part is working or not.
- WifiConnect Connect to wifi.
- WifiDisConnect Disconnect from your wifi network.
- Reboot Reboot esp module
- Reset Reset the esp module to it's defaults. It uses the values from the sketch when it's uploaded.
- Save Save changes to the esp's EEPROM
- Settings Show the current settings stored in the esp's EEPROM
piokuc
#9 Post by piokuc » 11 Aug 2016, 07:46
Very very thanks for help :)
