Spike08122
#1
Post
by Spike08122 » 21 Aug 2016, 13:26
I use a temperature sensor on ESP. The values are sent via MQTT to an RPI with FHEM. but the connection breaks off again. How about the rules, check the connection and trigger a restart of the ESP at demolition.
Sorry for my bad englisch.
I hope the question is understandable.
Greetings
Spike
sorry for my bad english
dduley
#2
Post
by dduley » 21 Aug 2016, 16:49
Spike08122 wrote:I use a temperature sensor on ESP. The values are sent via MQTT to an RPI with FHEM. but the connection breaks off again. How about the rules, check the connection and trigger a restart of the ESP at demolition.
Greetings
Spike
Hi Spike,
What version are you using? In later versions of ESPEasy there is a parameter under Tools\Advanced called Connection Failure Threshold. If this is set to 0 the ESP will not react to connection failures. Set this to a number like 30 and the ESP will reset itself after 30 failures.
Dave
Spike08122
#3
Post
by Spike08122 » 21 Aug 2016, 23:30
Hi Dave,
i use Build R108, and i have fond this point. i try it with 30. i hope this is the solution of the problem.
thank you for the help.
Spike
Users browsing this forum: Anthropic Claude Bot [bot], Google [Bot], Smotek7 and 29 guests
