MQTT and Thingspeak at the same time
petrho
#1 Post by petrho » 23 Jul 2016, 14:00
I would like to have both MQTT and Thingspeak support at the same time. Is it possible to make it via the rule engine?
//Peter
sonnyboy
Re: MQTT and Thingspeak at the same time
#2 Post by sonnyboy » 19 Aug 2016, 14:01
Like the idea :)
nonflammable
#3 Post by nonflammable » 19 Aug 2016, 18:41
i think it is possible temporarily with two esp8266 configured separately (first with MQTT, second with Thingspeak) and enabled synchronization between them :)
or use SendToHTTP in rules eg.
SendToHTTP 184.106.153.149,80,/update.html?key=YOURKEY&field1=[your#value]
Drum
#4 Post by Drum » 22 Aug 2016, 12:25
I don't see why you can not use Rules to send MQTT and the Thingspeak template. I used Domoticz HTTP template and MQTT via rules. I found it was not that reliable in an older version, R104 or R107 I think. The rules would sometimes send the first of the BME280 values and the other 2 would be "null". It worked perfect for a while then it stopped, no idea why. The new versions may work better, there is a newer version of PUBSUB.
My fix was to just switch to openHab MQTT and stopped using rules for sending MQTT. I don't use Thinkgspeak so I can't help there.
sonnyboy
#5 Post by sonnyboy » 22 Aug 2016, 21:02
nonflammable wrote: or use SendToHTTP in rules eg.
I cant get this to work
SendToHTTP 184.106.153.149,80,/update.html?key=mykey&field1=[garaget#Humidity]
Nothing gets updated on Thingspeak, any suggestion?
i got this in the log
128939493 : EVENT: garaget#Humidity=68.00
nonflammable
#6 Post by nonflammable » 23 Aug 2016, 11:31
sonnyboy wrote: I cant get this to work
http://www.esp8266.nu/index.php/Tutorial_Rules
On garaget#Humidity do
nonflammable
#7 Post by nonflammable » 27 Aug 2016, 09:07
Solved ?
sonnyboy
#8 Post by sonnyboy » 27 Aug 2016, 09:22
nonflammable wrote:Solved ?
I cant get this to work. My friend petrho will test this this weekend.
Got no error in the log, but thingspeak doesent update.
petrho
#9 Post by petrho » 29 Aug 2016, 20:32
works fine here...
petrho
#10 Post by petrho » 29 Aug 2016, 21:12
But why cant I send multiple commands?
On System#Uptime do
SendToHTTP 184.106.153.149,80,/update.html?key=xxx&field1=[Temp_Hum#Temperature]
SendToHTTP 184.106.153.149,80,/update.html?key=xxx&field2=[Temp_Hum#Humidity]
SendToHTTP 184.106.153.149,80,/update.html?key=xxx&field3=[System#Uptime]
only sent the first line...
nonflammable
#11 Post by nonflammable » 30 Aug 2016, 00:09
petrho wrote:But why cant I send multiple commands?
try to add empty line after "endon" and space before SendToHTTP :)
On Clock#Time do
petrho
#12 Post by petrho » 30 Aug 2016, 00:29
On Clock#Time do
Unfortunately same problem...
nonflammable
#13 Post by nonflammable » 30 Aug 2016, 12:57
petrho wrote: Unfortunately same problem...
this should be ok :) (Currently, a single channel can only be updated once every 15 seconds.)
On Clock#Time do
 SendToHTTP 184.106.153.149,80,/update.html?key=xxx&field1=[Temp_Hum#Temperature]&field2=[Temp_Hum#Humidity]&field3=[System#Uptime]
petrho
#14 Post by petrho » 30 Aug 2016, 14:39
On Clock#Time do
aha - you are right. Is it any delay command possible in the rule engine?
nonflammable
#15 Post by nonflammable » 30 Aug 2016, 23:01
petrho wrote: aha - you are right. Is it any delay command possible in the rule engine?
Yes :)
Delay <milliseconds>
eg.
On Clock#Time do
 Delay 15000
There are all commands:
http://www.esp8266.nu/index.php/ESPEasy ... _Reference
