is it possible to configure more then one event in rules?
jdemas
#1 Post by jdemas » 31 Aug 2016, 15:25
it's possible to trigger one event once a day automaticly.
i want to trigger the same event more then once a day in the rules
(stand alone)
i tried but i don't get it done
On Clock#Time=All,08:00 do
test
On Clock#Time=All,12:00 do
test
on test do
Pulse,13,0,900
Pulse,13,1,2400
Pulse,13,0,900
Pulse,13,1,2400
what's missing or isn't it possible
Jeffrey
Drum
Re: is it possible to configure more then one event in rules?
#2 Post by Drum » 31 Aug 2016, 22:28
Check the tutorial on rules, http://www.esp8266.nu/index.php/Tutorial_Rules
I think you need an "endon" for every "on"
Other than that I don't see any reason it shouldn't work, but I am not an expert on this...
jdemas
#3 Post by jdemas » 02 Sep 2016, 17:23
Yes i tried that
test
test
on test do
Pulse,13,0,900
Pulse,13,1,2400
Pulse,13,0,900
Pulse,13,1,2400
when i set even one endon in the list it will not work
without endon's it runs only the first time
thanks
costo
#4 Post by costo » 02 Sep 2016, 22:47
Did you try something like this ?
Pulse,13,0,900
Pulse,13,1,2400
Pulse,13,0,900
Pulse,13,1,2400
Pulse,13,0,900
Pulse,13,1,2400
Pulse,13,0,900
Pulse,13,1,2400
Martinus
#5 Post by Martinus » 03 Sep 2016, 10:17
Running "test" as a command will not work. You have to create an event like this:
  event test
  event test
on test do
  Pulse,13,0,900
  Pulse,13,1,2400
  Pulse,13,0,900
  Pulse,13,1,2400
jdemas
#6 Post by jdemas » 04 Sep 2016, 10:27
Thanks both solutions work
martinus your solution saves a lot of karakters
thanks a lot
Users browsing this forum: Anthropic Claude Bot [bot], Perplexity.ai [bot] and 2 guests
