Webserver Seems to be Blocked when DHT configured
tooblippe
#1 Post by tooblippe » 14 Sep 2016, 21:50
The more I play with espeasy the more I like it. This project could still go far!
It seems that when i Connect and configure a DHT22 the webserver is blocked most of the time and I only get connected via browser sporadically.
Any experience with this issue form someone.
Tobie
Drum
Re: Webserver Seems to be Blocked when DHT configured
#2 Post by Drum » 15 Sep 2016, 11:54
Which version of ESPEasy are you using and which browsers are giving you problems.
Also, and very important can you check to see if it is restarting. Maybe post a picture and schematic?
I have several units running for 6 months with DHT-22 and other sensors and have not seen this problem except when there are power issues causing reboots, almost always on breadboards.
Of course you could be having another issue.
tooblippe
#3 Post by tooblippe » 15 Sep 2016, 13:07
HI,
Thanks for the reply. I am using the latest - R120 version. I am quite new to EASYESP and the documentation is sparse and difficult to get to but I think I have most of the info that is written down.
Is R120 more or less stable than R108?
The system does not restart. I am using it connected to a NODEMCu v1 and of course the connected DHT22 supplied from the Vin(5V) pin.
If I keep on clicking on the refresh or links on the web page I eventually get in (Chrome).
It seems that the web server connects a small time after the DHT has made a reading and send the MQTT message.
Then there is a small window of time where the webserver responds.
thanks
