New ESP Device found - ESP8266 WiFi Relay V3.1
moelski
#1 Post by moelski » 25 Sep 2016, 19:13
Hi @all,
I´m not sure if anyone else found this but today I stumble over the "ESP8266 WiFi Relay V3.1" on ebay.de:
http://www.ebay.de/itm/302065993872
And after a short search with google I found the original vendor:
https://ex-store.de/ESP8266-WiFi-Relay-V31
What´s special about this device ... it´s flush-mounting able.
Did anyone of you guys bought this and give it a try?
The original firmware is closed source so using ESP Easy with this would be great ;)
greetings
Dominik
regards
Dominik
pmayer
Re: New ESP Device found - ESP8266 WiFi Relay V3.1
#2 Post by pmayer » 26 Sep 2016, 00:09
I've bought the version 3, see http://www.esp8266.nu/forum/viewtopic.p ... 7597#p7597
Works flawlessly with easpeasy, as stated in my post. But you have to either switch two GPIO Pins or write a rule to do that for you.
cheers,
p
timsson
#3 Post by timsson » 30 Sep 2016, 15:07
Is the Flash Size 512/1024 or 4096?
bobdvb
#4 Post by bobdvb » 04 Oct 2016, 11:29
Looks like an ESP-07 with 1024kB.
