after reading a lot of this forum I decided to start with Domoticz on a RPi3.
Testsetup : ESP8266-201 with firmware R120, Domoticz on RPI 3.
1st I've flashed the ESP and connected a BMP085 sensor on it, this works.
Now I tried to connect the device with Domoticz;
I've made a dummy sensor and a baro/hum/temp device, noted the IDX.
In the ESP I set this IDX, now it should work, but it doesn't.
When I look at the LOG in the ESP I see that every 10 seconds (my setting) a update of readout is done,
I cannot see in the log the data is send. Is the sending of the values towards domotics visible in de LOG ?
Is there something I've forgotten ?
My first Domoticz try
Re: My first Domoticz try
All,
problem is solved
I 've looked in the wrong column, ID instead of IDX
works perfect !
problem is solved
works perfect !
