Somfy RTS: Firmware - regression with Eolis 3D ?
MatrixRewriter
#1 Post by MatrixRewriter » 01 Feb 2024, 14:43
Hi all,
I have a Somfy Eolis 3D WireFree RTS wind detector that I've been using for a few years.
It sends out a regular "ping " (every ~18min 30s) when there's no wind, plus an immediate message when there is wind.
With the older RFLink firmware from 2017, it worked - although both pings and immediate messages were indistinguishable from each other (both received as STOP commands) so it required some time-based logic in Home Assistant to tell them apart. But it worked.
But with the latest RFLink firmware 1.51, when wind is detected, absolutely nothing is received from RFLink. And absolutely nothing is logged (on [rflink.protocol]).
HOWEVER the periodic ping is still received, as follows (Home Assistant RFLink debug logs):
2024-02-01 11:04:44.405 WARNING (MainThread) [rflink.protocol] dropping invalid data: 20;03;DEBUG;RTS P2;xxxxxxxxxxxxxxxxxxxx;
2024-02-01 11:04:44.409 DEBUG (MainThread) [rflink.protocol] received data: ;SWITCH=01;CMD=STOP;
2024-02-01 11:04:44.409 DEBUG (MainThread) [rflink.protocol] decoded packet: {'node': 'gateway', 'protocol': 'rts', 'id': 'xxxxxxx', 'switch': '01', 'command': 'stop'}
Note - Home Assistant debug logs enabled as follows:
  logs:
    rflink: debug
    homeassistant.components.rflink: debug
So to summarize it:
* The "beacon" vs "wind" signals are obviously different
* In 2017 firmwares RFLink reports both, but they are exposed identically
* In 2024 firmware RFLink only reports "beacon" and not "wind".
Is this a known regression with recent firmwares? (I only tried 1.51 so far).
Thanks in advance!
Stuntteam
Site Beheer
Re: Somfy RTS: Firmware - regression with Eolis 3D ?
#2 Post by Stuntteam » 01 Feb 2024, 16:35
Hmm, strange,..
At least not intentional.
Can you make debug logs?
(see: https://www.rflink.nl/develop.php)
MatrixRewriter
#3 Post by MatrixRewriter » 02 Feb 2024, 13:52
Sure! I have dismounted the device and am currently collecting logs in a quieter RF environment. I'll get back to you as soon as I have captured the signals :)
MatrixRewriter
#4 Post by MatrixRewriter » 02 Feb 2024, 14:28
I followed the instructions and enabled these options:
* Serial Port Logging
* Log Mode: Debug
* Log Mode: Unhandled (as a bonus)
With this, I have successfully captured the periodic beacon from the device:
20;05;DEBUG;RTS P1;a0ee0000b0f4e4c40019;
20;06;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
20;07;DEBUG;RTS P2;a0ee0000b0f4e48400;
20;08;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
20;09;DEBUG;RTS P1;a0ee0000b0f4e4c40019;
20;0A;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
20;0B;DEBUG;RTS P2;a0ee0000b0f4e48400;
20;0C;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
--- 18 minutes later ---
20;0D;DEBUG;RTS P1;a0ee0000b0f4e4c40019;
20;0E;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
20;0F;DEBUG;RTS P2;a0ee0000b0f4e48400;
20;10;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
20;11;DEBUG;RTS P1;a0ee0000b0f4e4c40019;
20;12;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
20;13;DEBUG;RTS P2;a0ee0000b0f4e48400;
20;14;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
I don't see any DEBUG;Pulses.
And also, when shaking the device (to simulate wind) I get absolutely nothing in RFLink.
MatrixRewriter
#5 Post by MatrixRewriter » 02 Feb 2024, 15:36
Ok, so for me:
* firmware 1.51 (with bundled RFLink Loader) do *not* display the Pulses info for RTS
* firmware 1.50 (with bundled RFLink Loader) do *not* display the Pulses info for RTS
* firmware 1.48 (with bundled RFLink Loader) properly displays the Pulses info for RTS
So I went back to firmware 1.48 and captured the Pulses info for the beacons (spaced by ~ 18 minutes):
------------ beacon --------
2024-02-02 15:09:52 - 20;04;DEBUG;Pulses=440;Pulses(uSec)=0,570,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,2490,4770,1200,1200,1200,1200,540,540,540,540,570,540,540,540,540,540,1200,1200,540,570,1200,570,540,570,540,1200,540,540,1200,1200,540,540,1200,570,570,570,540,1200,540,540,1200,1200,540,540,1200,570,540,570,540,1230,1200,570,540,570,540,570,540,570,540,570,540,570,540,1200,570,540,540,570,540,540,570,540,1200,1200,1200,1200,1200,570,540,570,540,1230,1200,570,540,570,540,1200,1200,570,540,1200,570,540,540,570,1200,1200,540,570,570,540,540,540,570,540,540,540,540,540,570,540,570,540,540,570,570,540,570,540,540,570,1200,570,540,1200,540,570,1200,570,630,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1200,1260,1200,1200,570,540,540,570,540,540,540,540,570,540,1200,1200,570,570,1200,570,540,570,540,1200,540,540,1200,1200,570,540,1200,570,570,570,540,1200,540,540,1200,1200,570,540,1200,570,540,570,540,1230,1200,570,540,570,540,570,540,570,540,570,540,570,540,1200,540,540,570,570,540,540,540,540,1200,1200,1200,1200,1200,570,540,570,540,1230,1200,570,540,570,540,1200,1200,1200,540,540,540,540,570,540,1200,1200,570,540,570,540,540,540,540,540,570,540,570,540,540,570,540,540,570,570,540,540,570,540,540,540,1200,570,540,570,540,1200,1200,570,600,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,540,540,540,540,570,540,540,570,540,540,1200,1230,540,540,1200,570,540,570,540,1200,540,540,1200,1200,540,540,1200,570,540,570,540,1200,570,540,1200,1200,540,540,1200,570,540,570,540,1200,1200,570,540,570,540,570,540,570,540,570,540,570,540,1200,570,540,540,540,540,540,570,540,1200,1200,1200,1200,1200,570,540,600,540,1200,1200,570,540,570,540,1200,1200,1200,570,540,540,540,570,540,1200,1200,540,570,540,540,570,540,570,540,540,540,540,540,570,540,540,570,540,570,540,540,570,540,570,540,1200,570,540,570,540,1200,1200,570,6990;
20;05;Debug;RTS P1;a0ee0000b0f4e4c40019;
20;07;Debug;RTS P2;a0ee0000b0f4e48400;
20;09;Debug;RTS P3;;
20;0A;RTS;ID=1000000;SWITCH=01;CMD=STOP;
2024-02-02 15:09:54 - 20;0B;DEBUG;Pulses=438;Pulses(uSec)=2550,2460,2460,2460,2460,2490,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,540,540,570,540,570,540,540,570,540,540,1200,1200,540,540,1200,570,540,570,540,1200,540,570,1200,1200,540,540,1200,570,540,570,540,1200,570,540,1200,1230,540,540,1200,570,540,570,540,1200,1200,570,540,570,540,570,540,570,540,570,540,570,540,1200,540,540,540,540,540,540,570,540,1200,1200,1230,1200,1200,570,540,570,540,1200,1200,570,540,570,540,1200,1230,570,540,1200,540,540,540,540,1200,1200,540,570,570,540,570,540,540,570,540,540,540,540,570,540,540,570,540,540,570,540,570,540,540,540,1200,570,540,1200,540,570,1200,570,660,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,570,540,540,540,540,570,570,540,540,540,1200,1200,570,540,1200,570,540,570,540,1200,570,570,1200,1200,570,540,1200,570,540,570,540,1200,540,540,1200,1230,540,540,1200,570,540,570,540,1200,1200,570,540,570,540,570,540,570,570,570,540,570,540,1200,540,540,570,540,540,540,540,540,1200,1200,1230,1200,1200,570,540,570,540,1200,1200,570,540,570,540,1200,1230,1200,540,540,570,540,570,540,1200,1200,570,540,570,540,540,540,540,540,570,540,540,540,540,540,570,540,570,540,540,540,540,540,570,540,1200,570,540,570,540,1200,1200,570,630,2460,2460,2490,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,540,540,570,540,540,600,540,540,570,540,1200,1200,540,540,1200,570,540,570,540,1200,570,570,1200,1200,540,540,1200,570,540,570,540,1200,570,540,1200,1230,570,540,1200,570,540,570,540,1200,1200,570,540,570,540,570,540,570,570,570,540,570,540,1200,540,540,540,540,570,540,570,540,1200,1200,1230,1200,1200,570,540,570,540,1200,1200,570,540,570,540,1200,1200,1200,540,540,540,540,540,540,1200,1200,540,540,570,540,570,540,540,570,540,540,570,540,570,540,540,570,540,540,570,540,540,540,540,540,1200,570,540,570,540,1200,1200,570,6990;
20;0C;Debug;RTS P1;a0ee0000b0f4e4c40019;
20;0D;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
20;0E;Debug;RTS P2;a0ee0000b0f4e48400;
20;0F;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
20;10;Debug;RTS P3;;
20;11;RTS;ID=1000000;SWITCH=01;CMD=STOP;
------- beacon ---
2024-02-02 15:28:10 - 20;12;DEBUG;Pulses=440;Pulses(uSec)=30,480,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2520,4770,1200,1200,1200,1200,540,540,570,540,570,540,540,540,570,540,1200,1200,540,540,1200,570,540,570,540,1230,540,540,1200,1200,540,540,1200,570,540,570,540,1200,540,540,1230,1200,540,540,1200,570,540,570,540,1200,1200,570,540,570,540,600,540,570,540,570,540,570,540,1200,570,540,540,540,540,540,570,540,1200,1230,1200,1200,1200,570,540,570,540,1200,1200,570,540,570,540,1230,1200,570,540,1200,540,540,540,570,1200,1200,540,570,570,540,570,540,570,540,540,540,540,540,570,540,570,540,540,570,570,540,570,540,540,540,1200,570,540,1200,540,570,1200,570,600,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,570,540,540,570,540,570,540,540,570,540,1200,1200,570,540,1200,570,570,570,540,1200,570,540,1200,1200,570,540,1200,570,540,570,540,1230,540,540,1200,1200,570,540,1200,570,540,570,540,1200,1200,570,540,570,540,570,540,570,540,570,540,570,540,1200,540,540,570,540,570,540,540,570,1200,1200,1200,1200,1200,570,540,570,540,1200,1200,570,570,570,540,1200,1200,1200,540,570,540,540,570,540,1200,1200,540,570,570,540,570,540,540,540,570,540,570,540,540,540,540,540,570,540,570,540,570,540,570,540,1200,570,540,570,540,1200,1200,570,630,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1230,540,540,540,540,570,540,540,540,570,540,1200,1200,540,540,1200,570,570,570,540,1200,540,540,1200,1200,540,540,1200,570,540,570,540,1230,570,540,1200,1200,540,540,1200,570,540,570,540,1200,1200,570,570,570,540,570,540,570,540,570,540,570,540,1200,570,540,540,540,540,540,570,570,1200,1200,1200,1200,1200,570,540,570,540,1200,1200,570,570,570,540,1200,1200,1200,570,540,540,570,540,540,1200,1200,540,570,540,540,570,540,540,540,540,540,540,540,570,540,540,570,540,570,570,540,570,540,540,540,1200,570,540,570,540,1200,1200,570,6990;
20;13;Debug;RTS P1;a0ee0000b0f4e4c40019;
20;15;Debug;RTS P2;a0ee0000b0f4e48400;
20;16;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
20;17;Debug;RTS P3;;
20;18;RTS;ID=1000000;SWITCH=01;CMD=STOP;
2024-02-02 15:28:13 - 20;19;DEBUG;Pulses=438;Pulses(uSec)=2610,2460,2460,2460,2460,2460,2460,2460,2490,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,540,540,570,540,540,570,570,540,540,540,1200,1200,540,540,1200,570,540,570,540,1200,570,540,1230,1200,540,540,1200,570,540,570,540,1200,570,540,1200,1200,570,540,1200,570,540,570,540,1200,1200,570,540,570,540,570,540,570,540,600,540,570,540,1200,540,540,540,540,570,540,540,540,1200,1200,1200,1230,1200,570,540,570,540,1200,1200,570,540,570,540,1200,1200,600,540,1200,540,570,540,540,1200,1200,540,540,570,540,570,540,540,540,570,540,570,540,540,570,540,570,540,540,570,540,540,540,540,540,1200,570,540,1200,540,540,1200,570,630,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,540,540,540,540,540,540,570,540,570,540,1200,1200,570,540,1200,570,540,570,540,1200,570,540,1200,1200,540,540,1200,570,540,570,540,1200,570,540,1230,1200,540,540,1200,570,540,570,540,1200,1200,570,540,570,540,570,570,570,540,570,540,570,540,1200,570,540,540,540,540,540,540,540,1200,1230,1200,1200,1200,570,540,570,540,1200,1200,570,540,570,540,1230,1200,1200,570,540,570,540,540,540,1200,1200,570,540,540,540,540,540,570,540,570,540,540,540,540,540,570,540,540,570,570,540,540,540,570,540,1200,570,540,570,540,1200,1200,570,630,2460,2460,2460,2460,2460,2490,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,570,540,570,540,540,540,540,540,570,540,1200,1200,540,540,1200,570,540,570,540,1230,570,540,1200,1200,570,540,1200,570,540,570,540,1200,570,540,1230,1200,570,540,1200,570,540,570,540,1200,1200,570,540,570,540,570,540,570,540,570,540,570,540,1200,570,540,540,540,570,540,540,540,1200,1230,1200,1200,1200,570,540,570,540,1200,1200,570,540,570,540,1230,1200,1200,540,540,570,540,570,540,1200,1200,540,540,570,540,570,540,540,540,540,540,570,540,540,540,540,570,540,540,570,540,540,540,540,540,1200,570,540,570,540,1200,1200,570,6990;
20;1A;Debug;RTS P1;a0ee0000b0f4e4c40019;
20;1B;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
20;1C;Debug;RTS P2;a0ee0000b0f4e48400;
20;1D;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
20;1E;Debug;RTS P3;;
20;1F;RTS;ID=1000000;SWITCH=01;CMD=STOP;
Ok, next I will try to trigger a Wind alert again.
MatrixRewriter
#6 Post by MatrixRewriter » 02 Feb 2024, 16:33
Ok, managed to capture it! The wind alert (shaking the device) produces this (with firmware 1.48):
20;20;DEBUG;Pulses=440;Pulses(uSec)=0,570,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,570,540,570,540,570,540,570,540,570,540,1200,1200,570,540,1200,570,540,570,540,570,540,1200,1230,1200,540,540,1200,570,540,570,540,570,540,1200,1200,1200,570,540,1200,570,540,570,540,1200,1200,570,540,570,540,570,540,570,540,600,540,570,540,1200,570,540,540,540,540,540,570,540,1200,1200,1200,1230,1200,570,540,570,540,1200,1200,570,540,570,540,1200,1200,600,540,1200,570,540,540,570,1200,1200,540,540,570,540,570,540,570,540,570,540,570,540,570,540,570,540,570,540,570,540,570,540,570,540,1200,570,540,1230,540,570,1200,570,630,2460,2460,2460,2460,2460,2460,2490,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,540,540,540,570,540,570,540,540,570,540,1200,1200,540,540,1200,570,540,570,540,570,540,1200,1200,1200,540,540,1200,570,540,570,540,570,540,1200,1200,1200,570,540,1200,570,540,570,540,1200,1200,570,540,570,540,570,570,570,540,570,540,570,540,1200,540,540,570,540,540,540,540,570,1200,1230,1200,1200,1200,570,540,570,540,1200,1200,570,540,570,540,1230,1200,1200,540,570,540,540,570,540,1200,1200,540,540,570,540,540,570,540,540,570,540,540,540,540,570,540,540,540,540,540,540,540,570,540,540,1200,570,540,570,540,1200,1200,570,630,2460,2460,2460,2460,2460,2490,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,570,540,570,540,570,540,570,540,570,540,1200,1200,540,540,1200,570,540,570,540,570,570,1200,1200,1200,540,540,1200,570,540,570,540,570,540,1200,1200,1200,540,540,1200,570,540,570,540,1200,1200,570,540,570,540,570,540,570,540,570,540,570,540,1200,570,540,540,540,540,540,570,540,1200,1230,1200,1200,1200,570,540,570,540,1200,1200,570,540,570,540,1230,1200,1200,570,540,540,540,540,540,1200,1200,540,540,570,540,570,540,570,540,570,540,570,540,570,540,570,540,540,540,570,540,570,540,570,540,1200,570,540,570,540,1200,1200,570,6990;
20;21;Debug;RTS P1;a0ef0001b0f4e4c40019;
20;22;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
20;23;Debug;RTS P2;a0ef0001b0f4e48400;
20;24;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
20;25;Debug;RTS P3;;
20;26;RTS;ID=1000000;SWITCH=01;CMD=STOP;
20;27;DEBUG;Pulses=440;Pulses(uSec)=0,540,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1230,540,570,540,570,540,540,540,540,540,540,1200,1200,570,540,1200,600,540,570,540,570,540,1200,1200,1200,540,570,1200,570,540,570,540,600,540,1200,1200,1200,540,540,1200,570,540,570,540,1200,1200,600,540,570,540,570,540,570,540,570,540,570,540,1200,570,540,570,540,540,540,570,540,1200,1200,1200,1200,1200,570,540,570,540,1200,1200,600,540,570,540,1200,1200,570,540,1200,570,540,540,570,1200,1200,570,540,570,540,540,540,570,540,570,540,540,540,540,540,570,540,540,570,540,540,570,540,570,540,1200,570,540,1200,570,540,1200,570,600,2490,2490,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1230,570,540,570,540,540,540,540,540,570,540,1200,1200,540,540,1200,570,540,570,540,570,540,1200,1200,1200,570,540,1200,570,540,570,540,600,540,1200,1200,1200,570,540,1200,570,540,570,540,1200,1200,600,540,570,540,570,540,570,540,570,540,570,540,1200,570,540,570,540,570,540,570,540,1200,1200,1200,1200,1200,570,540,570,540,1200,1200,600,540,570,540,1200,1200,1200,570,540,570,540,570,540,1200,1200,570,540,570,540,570,540,570,540,570,540,570,540,540,540,570,540,570,540,570,540,570,540,570,540,1200,570,540,570,540,1200,1200,540,630,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,4740,1200,1200,1200,1230,570,540,570,540,570,540,570,540,570,540,1200,1200,570,540,1200,570,540,570,540,540,570,1200,1200,1200,570,540,1200,570,540,570,540,570,570,1200,1200,1200,570,540,1200,570,540,570,540,1200,1200,570,540,570,540,570,540,570,540,570,540,540,570,1200,570,540,570,540,570,540,570,540,1200,1200,1200,1200,1200,570,540,570,540,1200,1200,570,540,540,540,1200,1200,1200,570,540,570,540,570,540,1200,1200,570,540,570,540,570,540,570,540,570,540,570,540,570,540,570,540,570,540,570,540,570,540,570,540,1200,540,540,570,540,1200,1200,540,6990;
20;28;Debug;RTS P1;a0ef0001b0f4e4c40019;
20;29;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
20;2A;Debug;RTS P2;a0ef0001b0f4e48400;
20;2B;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
20;2C;Debug;RTS P3;;
20;2D;RTS;ID=1000000;SWITCH=01;CMD=STOP;
20;2E;DEBUG;Pulses=440;Pulses(uSec)=0,510,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,570,540,570,540,570,540,540,570,540,540,1200,1200,540,540,1200,570,540,600,540,1200,570,540,1200,1200,540,540,1200,570,540,570,540,1200,570,540,1200,1200,540,540,1200,570,540,570,540,1200,1200,570,540,600,540,570,540,570,540,570,540,570,540,1200,540,540,540,540,540,540,570,540,1230,1200,1200,1200,1200,570,540,570,540,1200,1200,570,540,600,540,1200,1200,570,540,1200,540,540,540,540,1200,1200,540,570,570,540,570,540,540,540,540,540,540,540,570,540,540,570,540,540,570,540,570,540,570,540,1200,570,540,1200,540,570,1200,570,630,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,600,540,540,540,540,540,570,540,540,540,1200,1200,570,540,1200,570,540,600,540,1200,540,540,1200,1200,570,540,1200,570,540,570,540,1200,570,540,1200,1200,540,570,1200,570,540,570,540,1200,1200,570,540,600,540,570,540,570,540,570,540,570,540,1200,540,540,570,540,540,540,540,540,1230,1200,1200,1200,1200,570,540,570,540,1200,1200,570,540,600,540,1200,1200,1200,540,540,570,540,570,540,1200,1200,570,540,570,540,540,540,540,540,570,540,540,540,540,540,570,540,570,540,570,540,540,540,570,540,1200,570,540,570,540,1200,1200,570,630,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,540,540,570,540,540,540,540,570,540,540,1200,1200,540,540,1200,570,540,570,540,1200,570,540,1200,1200,540,540,1200,570,540,570,570,1200,570,540,1200,1200,570,540,1200,570,540,570,540,1200,1230,570,540,570,540,570,540,570,540,570,540,570,540,1200,540,540,540,540,570,570,570,540,1200,1200,1200,1200,1200,570,540,570,540,1200,1200,570,540,570,540,1200,1200,1200,570,540,540,540,570,540,1200,1230,540,570,570,540,570,540,540,540,540,540,570,540,570,540,540,570,540,540,570,540,570,540,540,570,1200,570,540,570,540,1200,1200,570,6990;
20;2F;Debug;RTS P1;a0ee0000b0f4e4c40019;
20;30;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
20;31;Debug;RTS P2;a0ee0000b0f4e48400;
20;32;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
20;33;Debug;RTS P3;;
20;34;RTS;ID=1000000;SWITCH=01;CMD=STOP;
20;35;DEBUG;Pulses=440;Pulses(uSec)=30,930,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,2490,4770,1200,1200,1200,1200,540,540,540,540,540,540,540,540,570,540,1200,1200,540,570,1200,570,540,570,540,1200,540,540,1200,1200,540,540,1200,570,570,570,540,1200,540,540,1200,1200,540,540,1200,570,540,570,540,1230,1200,570,540,570,540,570,540,570,540,570,540,570,540,1200,570,540,540,570,540,540,570,540,1200,1200,1200,1200,1200,570,540,570,540,1230,1200,570,540,570,540,1200,1200,570,540,1200,570,540,540,540,1200,1200,540,570,570,540,570,540,570,540,540,540,540,540,570,540,570,540,540,570,570,540,570,540,540,540,1200,570,540,1200,540,570,1200,570,600,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,570,540,540,540,540,570,540,540,570,540,1200,1230,570,540,1200,570,540,570,540,1200,570,540,1200,1200,570,540,1230,570,540,570,540,1200,540,540,1200,1200,570,540,1200,570,540,600,540,1200,1200,570,540,570,540,570,540,570,540,570,540,570,540,1200,570,540,570,540,570,540,540,540,1200,1200,1200,1200,1200,570,540,600,540,1200,1200,570,540,570,540,1200,1200,1200,540,540,540,540,570,540,1200,1200,540,540,570,540,540,540,540,540,570,540,570,540,540,570,540,540,570,540,570,540,540,540,540,540,1200,570,540,570,540,1200,1200,570,600,2460,2460,2460,2490,2460,2460,2460,2460,2460,2460,2460,2490,4770,1230,1200,1200,1200,540,540,540,540,570,540,540,570,540,540,1200,1230,540,540,1200,570,540,570,540,1200,570,540,1200,1200,540,540,1200,570,540,570,540,1200,570,540,1200,1200,540,540,1200,570,540,570,540,1200,1200,570,540,570,540,570,540,570,540,570,540,570,540,1200,570,540,540,540,540,540,570,540,1200,1200,1200,1200,1200,570,540,600,540,1200,1200,570,540,570,540,1200,1200,1200,570,540,540,570,570,540,1200,1200,540,570,540,540,570,540,570,540,540,540,540,540,570,540,570,570,540,570,540,540,570,540,540,540,1200,570,540,570,540,1200,1200,570,6990;
20;36;Debug;RTS P1;a0ee0000b0f4e4c40019;
20;37;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
20;38;Debug;RTS P2;a0ee0000b0f4e48400;
20;39;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
20;3A;Debug;RTS P3;;
20;3B;RTS;ID=1000000;SWITCH=01;CMD=STOP;
EDIT: Upgraded to firmware 1.51 again, and in fact the Wind events are captured! It was probably just bad batteries in the Somfy device:
2024-02-02 16:40:20 - 20;1A;DEBUG;Pulses=440;Pulses(uSec)=0,570,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,570,540,540,570,540,570,540,540,570,540,1200,1200,570,540,1200,570,540,570,540,570,540,1230,1200,1200,570,540,1200,570,540,570,540,570,540,1200,1200,1230,570,540,1200,570,540,570,540,1200,1200,570,540,570,540,570,540,600,540,570,540,570,540,1200,540,540,570,540,540,540,540,570,1200,1200,1230,1200,1200,570,540,570,540,1200,1200,570,540,570,540,1200,1200,570,540,1200,540,540,540,540,1200,1200,540,540,570,540,540,540,570,540,570,540,570,540,540,570,540,540,570,540,540,540,540,540,540,540,1200,570,540,1200,570,540,1200,570,690,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,540,570,540,540,570,540,540,570,540,540,1200,1200,540,540,1200,570,540,570,540,570,540,1230,1200,1200,540,540,1200,570,540,570,540,570,540,1200,1200,1230,540,540,1200,570,540,570,540,1200,1200,570,540,570,540,570,540,600,540,570,540,570,540,1200,570,540,570,540,570,540,570,540,1200,1200,1200,1200,1200,570,540,570,540,1200,1200,570,540,570,540,1200,1230,1200,570,540,570,540,540,540,1200,1200,540,570,540,540,570,540,570,540,540,540,570,540,570,540,540,570,540,570,540,540,570,540,540,540,1200,570,540,570,540,1200,1200,570,660,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,570,540,540,540,540,540,570,540,570,540,1200,1200,570,540,1200,570,540,570,540,570,540,1230,1200,1200,570,540,1200,570,540,570,540,570,540,1200,1200,1230,540,540,1200,570,540,570,540,1200,1200,570,540,570,540,570,540,570,540,570,540,570,540,1200,570,540,570,540,570,540,540,540,1200,1200,1230,1200,1200,570,540,570,540,1200,1200,570,540,570,540,1200,1230,1200,570,540,570,540,570,540,1200,1200,570,540,570,540,570,540,570,540,570,540,540,570,540,540,540,540,570,540,540,540,540,540,570,540,1200,570,540,570,540,1200,1200,570,6990;
20;1B;DEBUG;RTS P1;a0ef0001b0f4e4c40019;
20;1C;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
20;1D;DEBUG;RTS P2;a0ef0001b0f4e48400;
20;1E;RTS;ID=1b0f4e2024-02-02 16:40:21 - 4;SWITCH=01;CMD=STOP;
20;1F;DEBUG;Pulses=418;Pulses(uSec)=1830,2460,2460,2490,4770,1200,1200,1200,1200,570,540,540,570,540,570,540,540,570,540,1200,1230,540,540,1200,570,540,570,540,570,540,1200,1200,1200,570,540,1230,570,540,570,540,570,540,1200,1200,1200,570,540,1200,570,540,600,540,1200,1200,570,540,570,540,570,540,570,540,570,540,570,540,1200,570,540,570,540,570,540,540,540,1200,1200,1200,1200,1200,570,540,600,540,1200,1200,570,540,570,540,1200,1200,570,540,1200,540,540,570,540,1200,1200,540,540,570,540,540,540,540,540,570,540,570,540,540,570,570,540,570,540,570,540,570,540,570,540,1200,570,540,1200,570,540,1200,570,630,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1230,1200,1200,1200,540,540,540,540,570,540,540,570,540,540,1200,1230,540,540,1200,570,540,570,540,570,540,1200,1200,1200,540,540,1200,570,540,570,540,570,540,1200,1200,1200,540,540,1200,570,540,600,540,1200,1200,570,540,570,540,570,540,570,540,570,540,570,540,1200,570,540,540,540,540,540,570,540,1200,1200,1200,1200,1200,570,540,600,540,1200,1200,570,540,570,540,1200,1200,1200,570,540,540,540,570,540,1200,1200,540,570,570,540,570,540,570,540,540,540,540,540,570,540,540,540,540,540,570,540,570,540,540,540,1200,570,540,570,540,1200,1200,570,600,2460,2460,2460,2490,2460,2460,2460,2460,2460,2460,2460,2490,4770,1230,1200,1200,1200,570,540,540,540,540,540,570,540,570,540,1200,1230,570,540,1200,570,540,570,540,570,540,1200,1200,1200,570,540,1230,570,540,570,540,570,540,1200,1200,1200,540,540,1200,570,540,600,540,1200,1200,570,540,570,540,570,540,570,540,570,540,570,540,1200,570,540,570,540,540,540,540,540,1200,1200,1200,1200,1200,570,540,600,540,1200,1200,570,540,570,540,1200,1200,1200,540,540,570,540,570,540,1200,1200,540,540,540,570,540,570,540,540,570,540,540,570,540,570,540,540,540,540,540,570,540,540,570,540,1200,570,540,570,540,1200,1200,570,6990;
20;20;DEBUG;RTS P1;a0ef0001b0f4e4c40019;
20;21;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
20;22;DEBUG;RTS P2;a0ef0001b0f4e484001d;
20;23;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
20;24;DEBUG;RTS P3;a0ef0001b0f4e484001d;
20;25;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
2024-02-02 16:40:52 - 20;26;DEBUG;Pulses=440;Pulses(uSec)=30,570,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,570,540,540,570,540,540,570,540,540,600,1200,1200,570,540,1200,570,540,570,540,1200,540,540,1200,1230,540,570,1200,570,540,570,540,1200,540,540,1200,1200,540,540,1200,570,540,570,540,1200,1200,570,540,570,540,570,540,570,540,570,540,570,570,1200,570,540,570,540,540,540,540,540,1200,1200,1200,1200,1230,570,540,570,540,1200,1200,570,540,570,540,1200,1200,570,540,1230,570,540,540,570,1200,1200,570,540,540,540,570,540,570,540,570,540,540,570,540,540,570,540,570,540,540,570,540,540,570,540,1200,570,540,1200,570,540,1200,570,600,2490,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,540,540,540,540,540,570,540,570,540,540,1200,1200,540,540,1200,570,540,570,540,1200,570,540,1200,1200,540,540,1200,570,540,570,540,1200,570,540,1200,1200,570,540,1200,570,540,570,540,1200,1200,570,540,570,540,572024-02-02 16:40:53 - 0,540,570,540,600,540,570,540,1200,540,540,540,540,570,540,570,540,1200,1200,1200,1230,1200,570,540,570,540,1200,1200,570,540,570,540,1200,1200,1230,540,570,540,570,540,540,1200,1200,540,540,570,540,570,540,540,540,540,540,570,540,570,540,540,570,540,540,570,540,540,540,540,570,1200,570,540,570,540,1200,1200,570,600,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,540,540,540,570,540,540,540,540,540,540,1200,1200,570,540,1200,570,540,570,540,1230,540,540,1200,1200,540,570,1200,570,540,570,540,1200,540,540,1230,1200,540,540,1200,570,540,570,540,1200,1200,570,540,570,540,570,540,570,540,570,540,570,540,1200,570,540,570,540,540,540,540,540,1200,1230,1200,1200,1200,570,540,570,540,1200,1200,570,540,570,540,1230,1200,1200,540,540,570,540,540,570,1200,1200,570,540,540,570,540,540,570,540,570,540,540,570,540,540,570,540,540,570,540,540,540,540,570,540,1200,570,540,570,540,1200,1200,570,6990;
20;27;DEBUG;RTS P1;a0ee0000b0f4e4c40019;
20;28;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
20;29;DEBUG;RTS P2;a0ee0000b0f4e48400;
20;2A;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
20;2B;DEBUG;Pulses=440;Pulses(uSec)=0,870,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,540,570,540,540,540,540,570,540,540,540,1200,1200,540,570,1200,570,540,570,540,1200,540,540,1200,1200,540,570,1200,570,540,570,540,1200,540,540,1200,1200,570,540,1200,570,540,570,540,1200,1200,570,540,570,540,570,540,570,540,570,540,570,540,1200,570,540,540,540,540,540,570,540,1200,1200,1200,1230,1200,570,540,570,540,1200,1200,570,540,570,540,1200,1200,600,540,1200,570,540,540,570,1200,1200,540,570,540,540,540,540,570,540,570,570,540,540,540,540,570,540,540,570,570,540,570,540,570,540,1200,570,540,1230,540,570,1202024-02-02 16:40:54 - 0,570,600,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,570,540,540,540,540,570,540,540,570,540,1200,1200,540,540,1200,570,540,570,540,1230,570,540,1200,1200,570,540,1200,570,540,570,540,1200,540,540,1230,1200,570,540,1200,570,540,570,540,1200,1200,570,540,570,540,570,570,570,540,570,540,570,540,1200,540,540,540,540,570,540,540,570,1200,1230,1200,1200,1200,570,540,570,540,1200,1200,570,540,570,540,1230,1200,1200,540,540,540,540,570,540,1200,1200,540,540,570,540,540,570,540,570,540,540,570,540,540,570,540,540,570,540,570,540,540,540,540,540,1200,570,540,570,540,1200,1200,570,630,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,540,540,540,540,540,540,540,570,540,540,1200,1200,540,540,1200,570,540,600,540,1200,540,540,1200,1200,540,540,1200,570,540,570,540,1200,570,540,1200,1200,540,540,1200,570,540,570,540,1200,1200,570,540,600,540,570,540,570,540,570,540,570,540,1200,570,540,540,540,540,540,570,540,1230,1200,1200,1200,1200,570,540,570,540,1200,1200,570,540,600,540,1200,1200,1200,570,540,570,540,540,570,1200,1200,540,570,570,540,540,540,570,540,540,570,540,540,570,540,570,540,540,570,540,540,570,540,540,570,1200,570,540,570,540,1200,1200,570,6990;
20;2C;DEBUG;RTS P1;a0ee0000b0f4e4c40019;
20;2D;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
20;2E;DEBUG;RTS P2;a0ee0000b0f4e48400;
20;2F;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
One more capture of a Wind event for good measure:
2024-02-02 16:43:54 - 20;30;DEBUG;Pulses=440;Pulses(uSec)=0,570,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,540,570,570,540,570,540,540,570,540,540,1200,1200,540,540,1200,570,540,570,570,570,540,1200,1200,1200,540,540,1200,570,540,570,540,570,540,1230,1200,1200,540,540,1200,570,540,570,540,1200,1200,570,540,570,540,570,540,570,540,570,540,570,540,1200,540,540,540,540,540,540,570,540,1230,1200,1200,1200,1200,570,540,570,540,1200,1200,570,540,570,570,1200,1200,570,540,1230,540,570,540,540,1200,1200,540,570,540,570,570,540,540,570,540,570,540,540,570,540,540,570,540,570,540,540,570,540,540,570,1200,570,540,1230,540,570,1200,570,630,2520,2460,2460,2460,2460,2460,2460,2460,2490,2460,2460,2490,4770,1200,1200,1200,1200,540,540,540,570,570,540,540,540,540,540,1200,1200,540,540,1200,570,540,570,540,570,540,1230,1200,1200,540,570,1200,570,540,570,540,570,540,1200,1200,1230,540,540,1200,570,540,570,540,1200,1200,570,540,570,540,570,540,600,540,570,540,570,540,1200,570,540,570,540,540,540,540,540,1200,1200,1200,1200,1200,570,540,570,540,1200,1200,570,540,570,540,1200,1200,1200,540,540,570,540,540,570,1200,1200,570,540,540,540,540,540,570,540,570,540,540,570,540,540,570,540,570,540,540,540,540,540,570,540,1200,570,540,570,540,1200,1200,570,630,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,540,540,570,540,570,570,540,540,570,540,1200,1200,540,540,1200,570,540,570,540,570,540,1230,1200,1200,540,540,1200,570,540,570,540,570,540,1200,1200,1230,570,540,1200,570,540,570,540,1200,1200,570,540,570,540,570,540,600,540,570,540,570,540,1200,540,540,540,540,570,540,540,540,1200,1200,1230,1200,1200,570,540,570,540,1200,1200,570,540,570,540,1200,1200,1200,540,540,540,540,540,540,1200,1200,540,540,570,540,570,540,570,540,540,540,570,540,540,570,540,570,540,540,570,540,570,540,540,540,1200,570,540,570,540,1200,1200,570,6990;
20;31;DEBUG;RTS P1;a0ef0001b0f4e4c40019;
20;33;DEBUG;RTS P2;a0ef0001b0f4e48400;
20;34;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
2024-02-02 16:43:55 - 20;35;DEBUG;Pulses=418;Pulses(uSec)=2550,2460,2460,2490,4770,1200,1230,1200,1200,540,540,540,540,540,540,540,570,540,540,1200,1200,540,570,1200,570,540,570,540,570,540,1200,1200,1200,540,540,1200,570,570,570,540,570,540,1200,1200,1200,540,540,1200,570,540,570,540,1230,1200,570,540,570,540,570,540,570,540,570,540,570,540,1200,540,540,540,570,570,540,570,540,1200,1200,1200,1200,1200,570,540,570,540,1230,1200,570,540,570,540,1200,1200,570,540,1200,540,570,540,540,1200,1200,540,570,540,540,570,540,540,540,540,570,540,540,570,540,540,570,540,540,570,540,570,540,570,540,1200,570,540,1200,540,540,1200,570,630,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1200,1260,1200,1200,540,540,540,570,540,540,570,540,570,540,1200,1200,570,570,1200,570,540,570,540,570,540,1200,1200,1200,540,540,1200,570,570,570,540,570,540,1200,1200,1200,540,540,1200,570,540,570,540,1230,1200,570,540,570,540,570,540,570,540,570,540,570,540,1200,570,540,570,570,540,540,540,540,1200,1200,1200,1200,1200,570,540,570,540,1230,1200,570,540,570,540,1200,1200,1200,540,540,570,540,540,540,1200,1200,570,540,540,540,540,540,570,540,570,540,540,540,540,540,570,540,540,570,570,540,540,540,570,540,1200,570,540,570,540,1200,1200,570,600,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,540,540,540,540,540,570,540,570,540,540,1200,1230,540,540,1200,570,540,570,540,570,540,1200,1200,1200,540,540,1200,570,540,570,540,570,540,1200,1200,1200,570,540,1200,570,540,600,540,1200,1200,570,540,570,540,570,540,570,540,570,540,570,540,1200,570,540,540,540,570,540,540,570,1200,1200,1200,1200,1200,570,540,600,540,1200,1200,570,540,570,540,1200,1200,1230,540,570,540,570,570,540,1200,1200,540,540,570,540,570,540,540,570,540,540,570,540,570,540,540,570,540,570,570,540,540,540,540,570,1200,570,540,570,540,1200,1200,570,6990;
20;36;DEBUG;RTS P1;a0ef0001b0f4e4c40019;
20;38;DEBUG;RTS P2;a0ef0001b0f4e484001d;
20;3A;DEBUG;RTS P3;a0ef0001b0f4e484001d;
20;3B;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
2024-02-02 16:44:30 - 20;3C;DEBUG;Pulses=440;Pulses(uSec)=30,510,2460,2460,2460,2460,2460,2490,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,540,540,540,540,540,540,540,570,540,540,1200,1200,540,540,1200,570,540,570,540,1200,540,570,1200,1200,540,540,1200,570,540,570,540,1200,540,540,1200,1230,540,540,1200,570,540,570,540,1200,1200,570,540,570,540,570,540,570,570,570,540,570,540,1200,570,540,540,540,540,540,570,540,1200,1200,1200,1200,1200,570,540,570,540,1200,1200,570,540,570,540,1200,1230,570,540,1200,540,540,540,540,1200,1200,540,570,540,540,540,540,570,540,540,570,540,540,570,540,570,540,540,570,540,540,570,540,540,570,1200,570,540,1200,540,570,1200,570,630,2460,2460,2490,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,570,540,540,570,540,600,540,540,570,540,1200,1200,570,540,1200,570,540,570,540,1200,540,570,1200,1200,570,540,1200,570,540,570,540,1200,540,540,1200,1230,570,540,1200,570,540,570,540,1200,1200,570,540,570,540,570,540,570,570,570,540,570,540,1200,540,540,570,540,540,540,540,540,1200,1200,1230,1200,1200,570,540,570,540,1200,1200,570,540,570,540,1200,1230,1200,540,570,540,540,570,540,1200,1200,570,540,570,540,540,540,540,540,570,540,570,540,540,570,540,540,570,540,570,540,540,540,540,540,1200,570,540,570,540,1200,1200,570,630,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,540,540,540,540,570,570,540,570,540,540,1200,1200,540,570,1200,570,540,570,540,1200,540,570,1200,1200,540,540,1200,570,540,570,540,1200,570,540,1200,1230,540,540,1200,570,540,570,540,1200,1200,570,540,570,540,570,540,570,570,570,540,570,540,1200,540,540,540,540,540,540,570,540,1200,1200,1200,1200,1200,570,540,570,540,1200,1200,570,540,570,540,1200,1230,1200,570,540,540,570,540,540,1200,1200,540,570,540,540,570,540,540,570,540,570,540,540,570,540,540,570,540,570,570,540,570,540,540,540,1200,570,540,570,540,1200,1200,570,6990;
20;3D;DEBUG;RTS P1;a0ee0000b0f4e4c40019;
20;3E;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
20;3F;DEBUG;RTS P2;a0ee0000b0f4e48400;
20;40;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
2024-02-02 16:44:33 - 20;41;DEBUG;Pulses=440;Pulses(uSec)=60,930,2490,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2460,2490,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,570,540,540,570,540,570,540,540,570,540,1200,1200,570,540,1200,570,540,570,540,1200,540,540,1200,1200,570,540,1200,570,540,570,540,1200,540,540,1200,1200,570,540,1200,570,540,570,540,1200,1230,570,540,570,540,570,540,570,540,570,540,570,540,1200,540,540,570,540,570,540,540,540,1200,1200,1200,1200,1200,570,540,570,540,1200,1200,570,540,570,540,1200,1200,570,540,1200,540,540,570,540,1200,1230,540,540,570,540,540,570,540,540,570,540,570,540,540,570,540,540,540,540,540,540,540,540,540,540,1200,570,540,1200,570,540,1200,570,660,2460,2460,2460,2460,2490,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,540,540,540,540,540,540,540,570,540,540,1200,1200,540,540,1200,570,540,570,540,1200,540,540,1200,1200,540,540,1200,570,540,570,540,1200,570,540,1200,1200,540,540,1200,570,540,570,540,1200,1230,570,540,570,540,570,540,570,540,570,540,570,540,1200,540,540,540,540,570,540,570,540,1200,1200,1200,1200,1200,570,540,570,540,1200,1200,570,540,570,540,1200,1200,1200,570,540,540,570,540,540,1200,1230,540,570,540,540,570,540,540,540,540,540,540,540,570,540,540,570,540,570,570,540,570,540,540,540,1200,570,540,570,540,1200,1200,570,630,2460,2460,2460,2460,2490,2460,2460,2460,2460,2460,2460,2490,4770,1200,1200,1200,1200,570,540,540,570,540,540,540,540,540,540,1200,1200,570,540,1200,570,540,570,540,1200,540,540,1200,1200,570,540,12024-02-02 16:44:34 - 200,570,540,600,540,1200,540,540,1200,1200,540,540,1200,570,540,570,540,1200,1200,570,540,570,540,570,540,570,540,570,540,570,540,1200,540,540,570,540,570,540,540,540,1200,1200,1200,1200,1200,570,540,570,540,1200,1230,570,540,570,540,1200,1200,1200,540,540,570,540,570,540,1200,1230,540,540,540,540,540,540,540,540,570,540,540,570,540,540,570,540,570,540,540,570,540,540,570,540,1200,570,540,570,540,1200,1200,570,6990;
20;42;DEBUG;RTS P1;a0ee0000b0f4e4c40019;
20;43;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
20;44;DEBUG;RTS P2;a0ee0000b0f4e48400;
20;45;RTS;ID=1b0f4e4;SWITCH=01;CMD=STOP;
Now the question is: how to distinguish these Wind events from regular beacons?
MatrixRewriter
#7 Post by MatrixRewriter » 10 May 2024, 16:55
Stuntteam wrote: 01 Feb 2024, 16:35 Hmm, strange,..
Hi @Stuntteam,
Did you get a chance to look into the debug logs that I posted? Hopefully this will allow to recognize the "wind" messages from the regular "beacon" ones...
That would be very helpful.
Thanks in advance!
mouze06
#8 Post by mouze06 » 29 May 2024, 12:59
the Eolis 3D seems to behave identical with a "Soliris sensor RTS". The RTS packet uses the command 0xE (Sensor) and should then be interpreted differently. The rolling code field is not used as such, but contains the current status. Bit 15 set (value 0001) indicates WIND present, bit 14 (value 0002) indicates SUN present. With no bits set, the message is not a "beacon", it represents the current status, ie. no WIND and no SUN.
The current firmware decodes the ID incorrect, by adding 0x1000000. And interprets the command incorrect, as STOP rather then SENSOR.
My Soliris sensor :
2024.05.29_07:53:35.753 20;62;DEBUG;RTS P1;a0e4000048869b; ---
2024.05.29_07:53:35.753 20;63;RTS;ID=148869b;SWITCH=01;CMD=STOP;
2024.05.29_08:01:01.209 20;65;DEBUG;RTS P1;a0e6000248869b; SUN
2024.05.29_08:01:01.209 20;66;RTS;ID=148869b;SWITCH=01;CMD=DOWN;
2024.05.29_10:42:31.085 20;1F;DEBUG;RTS P1;a0e7000348869b; SUN + WIND
2024.05.29_10:42:31.085 20;20;RTS;ID=148869b;SWITCH=01;CMD=UP;
MatrixRewriter
#9 Post by MatrixRewriter » 03 Jun 2024, 17:47
Thank you for the insightful response @mouze06, much appreciated!
@Stuntteam please, would it be possible to implement the fix to properly support these wind/sun bits? That would be awesome!
Thanks in advance ;)
