Multiple Dallas sensors
Dear.. I have used espeasy for my terrarium for years, with 5 dallas sensors on 1 pin.
After there was a power flow, my esp broke [power supply too]. Now a new esp [nodemcue V3] with espeasy [old version because everything worked. ]
But I can no longer get the config with 5 sensors to work. Tried different resistors, [I thought 4.7 worked, but that didn't work], put others in, but couldn't get it to work.
Can someone help me with the correct config, 5x dallas on 1 pin.
Re: Multiple Dallas sensors
Did you also replace the Dallas sensors after the power-issue, or only the ESP? And if the sensors are not replaced, it's still possible they are also broken...
Can you get it working with only 1 sensor on the GPIO pin?
NB: Upgrading to the latest ESPEasy release will probably give you the feature of having multiple (up to 4) Dallas sensors in a single task, that was added some time ago.
The problem is... I cannot test 1 because they ar separate in the terrarium.
I hope they are not broke, [ should mean i hava a lot of work to repleace them ]
Is there a way i can test?
Sometimes there are 2 sesnors:
360318: MQTT : Connection lost, state: Disconnected
360436: MQTT : Broker C002 connection failed (1/0)
361697: WD : Uptime 6 ConnectFailures 1 FreeMem 21584 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
362179: Command unknown: AUTH 2f3025cb1a64ad586fbcc835e1d1a72a
376790: SYS : 7.7
384756: SYS : 6
390589: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
390590: Subscribed to: domoticz/out
391698: WD : Uptime 7 ConnectFailures 0 FreeMem 19880 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
391858: Command unknown: AUTH b8698891a9dfbc9d3ad27f932c6f5597
421699: WD : Uptime 7 ConnectFailures 0 FreeMem 15560 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
422590: Command unknown: AUTH 1672be78bd052f07b8cbd5bb47f97431
423790: SYS : 7.9
444067: MQTT : Connection lost, state: Disconnected
444128: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
444129: Subscribed to: domoticz/out
448753: SYS : 7
451698: WD : Uptime 8 ConnectFailures 0 FreeMem 15816 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
452285: Command unknown: AUTH 0fd48ee0afd0262d5c582f87064470d7
470874: SYS : 8.8
481698: WD : Uptime 8 ConnectFailures 0 FreeMem 15728 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
481999: Command unknown: AUTH c0101eace28d9000572d29f9d022ea72
491152: MQTT : Connection lost, state: Disconnected
491210: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
491211: Subscribed to: domoticz/out
511697: WD : Uptime 9 ConnectFailures 0 FreeMem 15808 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
512189: Command unknown: AUTH 10b6636984ea0e4809da9d85907cea82
512753: SYS : 9
517790: SYS : 7.8
538075: MQTT : Connection lost, state: Disconnected
538194: MQTT : Broker C002 connection failed (1/0)
541698: WD : Uptime 9 ConnectFailures 1 FreeMem 22256 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
564790: SYS : 9.5
568349: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
568350: Subscribed to: domoticz/out
571697: WD : Uptime 10 ConnectFailures 0 FreeMem 17968 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
572095: Command unknown: AUTH 7c7202a91dfc40c510da7cf1ffdfd0a6
576753: SYS : 10
601697: WD : Uptime 10 ConnectFailures 0 FreeMem 15504 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
601787: Command unknown: AUTH bedd25581ebed5b4d2b4918d7d892fff
606570: DS : Temperature: Error! (28-bd-61-71-04-00-00-36 [DS18B20])
607285: MQTT : Connection lost, state: Disconnected
607326: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
607327: Subscribed to: domoticz/out
611790: SYS : 7.8
631698: WD : Uptime 11 ConnectFailures 0 FreeMem 12224 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
631999: Command unknown: AUTH ca892671a86381624abc518900dc5569
640753: SYS : 11
658790: SYS : 8.0
661698: WD : Uptime 11 ConnectFailures 0 FreeMem 15104 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
662193: Command unknown: AUTH bca678a9bddd069b5220f18bc3e9d174
665571: DS : Temperature: Error! (28-bd-61-71-04-00-00-36 [DS18B20])
679072: MQTT : Connection lost, state: Disconnected
679109: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
679110: Subscribed to: domoticz/out
691698: WD : Uptime 12 ConnectFailures 0 FreeMem 14344 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
691930: Command unknown: AUTH 987a863d669b1c6e528bb6ada98e03d2
704753: SYS : 12
2618: WiFi : Scan finished, found: 16
2623: WiFi : Best AP candidate: D.M. C8:7F:54:47:66:A0 Ch:9 (-53dBm) WPA/WPA2/PSK
2625: WIFI : Connecting D.M. C8:7F:54:47:66:A0 Ch:9 (-53dBm) WPA/WPA2/PSK attempt #0
2627: IP : Static IP : 192.168.5.110 GW: 192.168.5.1 SN: 255.255.255.0 DNS: 192.168.5.1
3652: WIFI : Connected! AP: D.M. (C8:7F:54:47:66:A0) Ch: 9 Duration: 1024 ms
3653: WIFI : Static IP: 192.168.5.110 (ESP-Easy-Terrarium-1) GW: 192.168.5.1 SN: 255.255.255.0 duration: 3 ms
3794: UDP : Start listening on port 8266
3794: firstLoopConnectionsEstablished
3886: NTP : NTP replied: delay 51 mSec Accuracy increased by 0.611 seconds
3888: Time set to 1722505146.611 Time adjusted by 2057.06 msec. Wander: 0.000 msec/second Source: NTP
3891: Local time: 2024-08-01 09:39:06
3904: MQTT : Intentional reconnect
3987: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
3988: Subscribed to: domoticz/out
4160: Command unknown: AUTH 687f0a5b70a7313ae6b5e9edcd628c53
31822: WD : Uptime 1 ConnectFailures 0 FreeMem 14472 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
32314: Command unknown: AUTH a383c3cc07acbd74bdbfc856de6016de
44428: MQTT : Connection lost, state: Disconnected
44450: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
44452: Subscribed to: domoticz/out
47914: SYS : 8.1
61822: WD : Uptime 1 ConnectFailures 0 FreeMem 14744 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
62023: Command unknown: AUTH 414105257d509ec8cc39ae2dfe82e7d9
64876: SYS : 1
84908: MQTT : Connection lost, state: Disconnected
85098: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
85099: Subscribed to: domoticz/out
91822: WD : Uptime 2 ConnectFailures 0 FreeMem 16000 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
92228: Command unknown: AUTH 86f0eeeb2bbaa4a0fb70b909daa7ddd8
94914: SYS : 7.9
121822: WD : Uptime 2 ConnectFailures 0 FreeMem 12664 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
128876: SYS : 2
141914: SYS : 7.4
151822: WD : Uptime 3 ConnectFailures 0 FreeMem 15744 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
151949: MQTT : Connection lost, state: Disconnected
152003: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
152004: Subscribed to: domoticz/out
152129: Command unknown: AUTH 878d188f03f98630984a01d8c5e671a1
172261: MQTT : Connection lost, state: Disconnected
172303: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
172304: Subscribed to: domoticz/out
177923: DS : Temperature: Error! (28-bd-61-71-04-00-00-36 [DS18B20])
181823: WD : Uptime 3 ConnectFailures 0 FreeMem 15728 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
182323: Command unknown: AUTH e31bf344a7084b533981d11f4162e2d4
188914: SYS : 8.9
192876: SYS : 3
211823: WD : Uptime 4 ConnectFailures 0 FreeMem 15840 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
213159: MQTT : Connection lost, state: Disconnected
213179: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
213180: Subscribed to: domoticz/out
235914: SYS : 7.4
236850: DS : Temperature: Error! (28-bd-61-71-04-00-00-36 [DS18B20])
241822: WD : Uptime 4 ConnectFailures 0 FreeMem 12856 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
242257: Command unknown: AUTH 2ee27d2c3135e9ec45b937a11b6188ad
256876: SYS : 4
266908: MQTT : Connection lost, state: Disconnected
267025: MQTT : Broker C002 connection failed (1/0)
271822: WD : Uptime 5 ConnectFailures 1 FreeMem 17688 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
272437: Command unknown: AUTH eafc5df76c267f90a0bf574d1b4a9026
282914: SYS : 7.4
295863: DS : Temperature: Error! (28-bd-61-71-04-00-00-36 [DS18B20])
297184: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
297185: Subscribed to: domoticz/out
301822: WD : Uptime 5 ConnectFailures 0 FreeMem 16528 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
302265: Command unknown: AUTH ecb451d6b620ba30263e3ca376692db1
320876: SYS : 5
329915: SYS : 50.8
331823: WD : Uptime 6 ConnectFailures 0 FreeMem 16376 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
332346: Command unknown: AUTH 0bc58ddee2f43caa9406b98e3def441c
350197: MQTT : Connection lost, state: Disconnected
350225: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
350226: Subscribed to: domoticz/out
354860: DS : Temperature: Error! (28-bd-61-71-04-00-00-36 [DS18B20])
361822: WD : Uptime 6 ConnectFailures 0 FreeMem 16000 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
362526: Command unknown: AUTH f877d5692d4db2b62cfb85b11049dec3
370233: MQTT : Connection lost, state: Disconnected
370344: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
370346: Subscribed to: domoticz/out
376914: SYS : 8.0
384876: SYS : 6
391822: WD : Uptime 7 ConnectFailures 0 FreeMem 15880 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
392426: Command unknown: AUTH 6105b82093433f21149c818d4f9108fe
413860: DS : Temperature: Error! (28-bd-61-71-04-00-00-36 [DS18B20])
421823: WD : Uptime 7 ConnectFailures 0 FreeMem 16056 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
422125: Command unknown: AUTH 3af778bea3d73d4a4f083ff761a5c46e
423914: SYS : 8.2
444193: MQTT : Connection lost, state: Disconnected
444226: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
444227: Subscribed to: domoticz/out
448876: SYS : 7
451822: WD : Uptime 8 ConnectFailures 0 FreeMem 17016 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
452708: Command unknown: AUTH 1d70ff0cde4eacb8ff2d426e1f05e093
470914: SYS : 9.2
481822: WD : Uptime 8 ConnectFailures 0 FreeMem 16056 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
482031: Command unknown: AUTH 7b01114d486d17dc6d4290f5f3189149
501445: MQTT : Connection lost, state: Disconnected
501472: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
501473: Subscribed to: domoticz/out
511822: WD : Uptime 9 ConnectFailures 0 FreeMem 17760 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
512061: Command unknown: AUTH 920f2ad79a834f862f9f579a90edfd10
512876: SYS : 9
517914: SYS : 8.3
531861: DS : Temperature: Error! (28-bd-61-71-04-00-00-36 [DS18B20])
538199: MQTT : Connection lost, state: Disconnected
538219: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
538220: Subscribed to: domoticz/out
541822: WD : Uptime 9 ConnectFailures 0 FreeMem 16544 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
542268: Command unknown: AUTH fdc18a4a9425391b588c1b1614144e8e
564914: SYS : 8.1
571823: WD : Uptime 10 ConnectFailures 0 FreeMem 17432 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
572472: Command unknown: AUTH eae297f6aa722ff968de69bb37d317b0
576876: SYS : 10
586907: MQTT : Connection lost, state: Disconnected
587157: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
587158: Subscribed to: domoticz/out
601822: WD : Uptime 10 ConnectFailures 0 FreeMem 15896 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
602278: Command unknown: AUTH c0d98689d8543045611c6a41077b9331
611915: SYS : 9.2
631822: WD : Uptime 11 ConnectFailures 0 FreeMem 17432 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
632192: MQTT : Connection lost, state: Disconnected
632302: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
632303: Subscribed to: domoticz/out
632397: Command unknown: AUTH 6f822165a2707227077f22c39be5021e
640876: SYS : 11
658914: SYS : 8.3
661822: WD : Uptime 11 ConnectFailures 0 FreeMem 17432 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
662197: Command unknown: AUTH 422b29464debbf4d7ae72b5ab4b1c88e
678945: MQTT : Connection lost, state: Disconnected
679007: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
679008: Subscribed to: domoticz/out
691822: WD : Uptime 12 ConnectFailures 0 FreeMem 16008 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
704876: SYS : 12
705915: SYS : 8.2
721822: WD : Uptime 12 ConnectFailures 0 FreeMem 17520 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
722022: Command unknown: AUTH a0a7994518498c23ea9a3e175b575507
736446: MQTT : Connection lost, state: Disconnected
736510: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
736511: Subscribed to: domoticz/out
751822: WD : Uptime 13 ConnectFailures 0 FreeMem 17968 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
752187: Command unknown: AUTH f60895e4882a7fa1dff931ef22e972de
752914: SYS : 9.1
768876: SYS : 13
781823: WD : Uptime 13 ConnectFailures 0 FreeMem 15848 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
782389: Command unknown: AUTH 2bf4c38af7c3c6731f74d7c919108e32
789158: MQTT : Connection lost, state: Disconnected
789178: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
789179: Subscribed to: domoticz/out
793043: DS : Temperature: Error! (28-82-df-b5-06-00-00-6a [DS18B20])
799914: SYS : 8.6
811823: WD : Uptime 14 ConnectFailures 0 FreeMem 17256 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
812126: Command unknown: AUTH c350da8d89322ead5418c53044611651
826861: DS : Temperature: Error! (28-bd-61-71-04-00-00-36 [DS18B20])
832876: SYS : 14
841822: WD : Uptime 14 ConnectFailures 0 FreeMem 16600 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
842802: Command unknown: AUTH 49cd3875134f966e9b2770ebe5b69626
846914: SYS : 7.9
849062: DS : Temperature: Error! (28-82-df-b5-06-00-00-6a [DS18B20])
856947: MQTT : Connection lost, state: Disconnected
857067: MQTT : Broker C002 connection failed (1/0)
871822: WD : Uptime 15 ConnectFailures 1 FreeMem 22192 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
872574: Command unknown: AUTH 254adddbd018f0ed8a0774a7a97c291e
887964: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
887965: Subscribed to: domoticz/out
893914: SYS : 7.7
896876: SYS : 15
901823: WD : Uptime 15 ConnectFailures 0 FreeMem 16840 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
902344: Command unknown: AUTH d229c42180e9ed993e14f244b9ae97ee
905063: DS : Temperature: Error! (28-82-df-b5-06-00-00-6a [DS18B20])
917156: MQTT : Connection lost, state: Disconnected
917245: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
917246: Subscribed to: domoticz/out
931823: WD : Uptime 16 ConnectFailures 0 FreeMem 19360 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
932429: Command unknown: AUTH ca44088a76065598129c1a52ee2f1bc1
940914: SYS : 8.6
944862: DS : Temperature: Error! (28-bd-61-71-04-00-00-36 [DS18B20])
960876: SYS : 16
961822: WD : Uptime 16 ConnectFailures 0 FreeMem 15800 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
962629: Command unknown: AUTH 0079259b5634a3335ec3f77a51192315
981158: MQTT : Connection lost, state: Disconnected
981195: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
981196: Subscribed to: domoticz/out
987914: SYS : 8.1
991823: WD : Uptime 17 ConnectFailures 0 FreeMem 15640 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
992343: Command unknown: AUTH f279fc50cd3e069fc6010d01325e7578
1003862: DS : Temperature: Error! (28-bd-61-71-04-00-00-36 [DS18B20])
1017064: DS : Temperature: Error! (28-82-df-b5-06-00-00-6a [DS18B20])
1018446: MQTT : Connection lost, state: Disconnected
1018567: MQTT : Broker C002 connection failed (1/0)
1021822: WD : Uptime 17 ConnectFailures 1 FreeMem 22192 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
1022404: Command unknown: AUTH 0a44f7342f9e41491ccf94ffdf6259a6
1024876: SYS : 17
1034918: SYS : 8.3
1048724: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
1048726: Subscribed to: domoticz/out
1051822: WD : Uptime 18 ConnectFailures 0 FreeMem 19912 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
1052721: Command unknown: AUTH 877919c1ba8abfcd63c810bad3378b74
1081822: WD : Uptime 18 ConnectFailures 0 FreeMem 17144 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
1081914: SYS : 80.7
1082621: Command unknown: AUTH 5830543112e4354b6197b704dcd66704
1088876: SYS : 18
1109156: MQTT : Connection lost, state: Disconnected
1109181: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
1109183: Subscribed to: domoticz/out
1111822: WD : Uptime 19 ConnectFailures 0 FreeMem 21944 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
1112142: Command unknown: AUTH 41ea4344e1e1f5a42636e899d7cdd749
1121864: DS : Temperature: Error! (28-bd-61-71-04-00-00-36 [DS18B20])
1128914: SYS : 7.8
1129065: DS : Temperature: Error! (28-82-df-b5-06-00-00-6a [DS18B20])
1141823: WD : Uptime 19 ConnectFailures 0 FreeMem 15992 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
1142626: Command unknown: AUTH a6106761a95c53dad2ee8a7663a64aaa
1149199: MQTT : Connection lost, state: Disconnected
1149276: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
1149277: Subscribed to: domoticz/out
1152876: SYS : 19
1171823: WD : Uptime 20 ConnectFailures 0 FreeMem 15800 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
1172563: Command unknown: AUTH 861f4a768554cfc4cd711a1d30e10e69
1172907: MQTT : Connection lost, state: Disconnected
1172936: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
1172937: Subscribed to: domoticz/out
1175914: SYS : 7.6
1185066: DS : Temperature: Error! (28-82-df-b5-06-00-00-6a [DS18B20])
1201822: WD : Uptime 20 ConnectFailures 0 FreeMem 15800 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
1202360: Command unknown: AUTH 94f50927430a95511020f29d662d1f92
1216877: SYS : 20
1222914: SYS : 8.0
1231822: WD : Uptime 21 ConnectFailures 0 FreeMem 15800 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
1232455: Command unknown: AUTH 470c4aed0167cb646671ee10dde53ddb
1239864: DS : Temperature: Error! (28-bd-61-71-04-00-00-36 [DS18B20])
1241067: DS : Temperature: Error! (28-82-df-b5-06-00-00-6a [DS18B20])
1242950: MQTT : Connection lost, state: Disconnected
1242978: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
1242979: Subscribed to: domoticz/out
1261822: WD : Uptime 21 ConnectFailures 0 FreeMem 16888 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
1262180: Command unknown: AUTH 8d5c4921c97036dac252ed3a3d5e1e36
1269914: SYS : 7.8
1280877: SYS : 21
1290907: MQTT : Connection lost, state: Disconnected
1291018: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
1291019: Subscribed to: domoticz/out
1291822: WD : Uptime 22 ConnectFailures 0 FreeMem 17568 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
1292383: Command unknown: AUTH 8232e38e32561a82052480df7ce979c7
1298866: DS : Temperature: Error! (28-bd-61-71-04-00-00-36 [DS18B20])
1316914: SYS : 8.6
1321822: WD : Uptime 22 ConnectFailures 0 FreeMem 16360 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
1322376: Command unknown: AUTH fe648854d68882bda9a301c2cc24fb6c
1337198: MQTT : Connection lost, state: Disconnected
1337242: MQTT : Connected to broker with client ID: Ter_ESP_terrarium
1337243: Subscribed to: domoticz/out
1344876: SYS : 22
1351822: WD : Uptime 23 ConnectFailures 0 FreeMem 20216 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
1352256: Command unknown: AUTH 82d931930087ebf7de59a6658fa9c3c6
1353068: DS : Temperature: Error! (28-82-df-b5-06-00-00-6a [DS18B20])
1357868: DS : Temperature: Error! (28-bd-61-71-04-00-00-36 [DS18B20])
1363914: SYS : 8.1
1381822: WD : Uptime 23 ConnectFailures 0 FreeMem 16424 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
1382065: Command unknown: AUTH d09d415b2edb4cc0160e072a4f42b98e
1394196: MQTT : Connection lost, state: Disconnected
1394317: MQTT : Broker C002 connection failed (1/0)
1408876: SYS : 23
1409075: DS : Temperature: Error! (28-82-df-b5-06-00-00-6a [DS18B20])
1410921: SYS : 8.3
Can you disable the MQTT controller just as a test?
Sometimes the MQTT controller takes up all CPU resources when trying to reconnect and since reading of Dallas sensors is rather timing critical, you may just experience issues there due to the MQTT controller constantly reconnecting.
This at least will help you to determine whether the sensors still work.
N.B. in later builds this stalling of the ESPEasy node when reconnecting to the MQTT broker is way less of a burden to the node. (latest test builds, not even the April release)
The version i use: ESP_Easy_mega_20220809_normal_ESP8266_1M_VCC Aug 9 2022
NOOB so if i need to upgrade. help me please..
strange thing, i see sometimes 2 dallassensors, and then they are gone..
Do i need the 4.7k or a other for 5 sensors?
log withouth mqtt:
log withouth mqtt:
233227: DS : Temperature: Error! (28-82-df-b5-06-00-00-6a [DS18B20])
235982: SYS : 5.1
241890: WD : Uptime 4 ConnectFailures 0 FreeMem 17000 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
242520: Command unknown: AUTH b88e2049a0e5e76e2843bd5d0d0c83b8
256945: SYS : 4
271890: WD : Uptime 5 ConnectFailures 0 FreeMem 20688 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
272062: Command unknown: AUTH 4dbe4e56809eb4bacb33843303a9eca3
282982: SYS : 5.8
301890: WD : Uptime 5 ConnectFailures 0 FreeMem 20968 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
302211: Command unknown: AUTH 4ffb618f0668e296b6facd06d9e590d0
320945: SYS : 5
329982: SYS : 5.3
331890: WD : Uptime 6 ConnectFailures 0 FreeMem 21304 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
332441: Command unknown: AUTH 446bd0c3621398c5d8a96235adf57e80
361891: WD : Uptime 6 ConnectFailures 0 FreeMem 22312 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
362599: Command unknown: AUTH 0f8b4973884484aedc0f914c2b8ad815
376982: SYS : 5.0
384945: SYS : 6
391890: WD : Uptime 7 ConnectFailures 0 FreeMem 22464 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
392427: Command unknown: AUTH 417fb84700fc7a612252982385d3c0e4
421890: WD : Uptime 7 ConnectFailures 0 FreeMem 22464 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
422556: Command unknown: AUTH d0116ee0b88dbfeac4ea43773ff8e740
423982: SYS : 5.6
448945: SYS : 7
451890: WD : Uptime 8 ConnectFailures 0 FreeMem 22464 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
452226: Command unknown: AUTH 4ff8cc3c293a6cdcc1ca7f8869a43373
470982: SYS : 5.1
481890: WD : Uptime 8 ConnectFailures 0 FreeMem 22464 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
482447: Command unknown: AUTH cdd256e5887a7a8622f953779dbf8350
511891: WD : Uptime 9 ConnectFailures 0 FreeMem 22464 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
512144: Command unknown: AUTH 5fc05143c70eaea193b22ab33be42bcb
512945: SYS : 9
517982: SYS : 5.0
541890: WD : Uptime 9 ConnectFailures 0 FreeMem 22440 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
542392: Command unknown: AUTH d09e5b75474882e641d9e9ff8fee1e10
564982: SYS : 5.2
571890: WD : Uptime 10 ConnectFailures 0 FreeMem 22440 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
572585: Command unknown: AUTH 1a56a7444bf75e659baf784babb687b8
576945: SYS : 10
587221: DS : Temperature: Error! (28-82-df-b5-06-00-00-6a [DS18B20])
601890: WD : Uptime 10 ConnectFailures 0 FreeMem 22464 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
602256: Command unknown: AUTH a9d5c73bcd076acdcaed674b061a0401
611982: SYS : 5.8
631890: WD : Uptime 11 ConnectFailures 0 FreeMem 22440 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
632472: Command unknown: AUTH b6a315f7a6a0b8eb07383aaf185c9aa8
640945: SYS : 11
658982: SYS : 5.0
661890: WD : Uptime 11 ConnectFailures 0 FreeMem 22440 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
691894: WD : Uptime 12 ConnectFailures 0 FreeMem 22440 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
692351: Command unknown: AUTH 92d8cbf1607a54e068e85671e674b617
704945: SYS : 12
705982: SYS : 5.5
721890: WD : Uptime 12 ConnectFailures 0 FreeMem 22440 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
751890: WD : Uptime 13 ConnectFailures 0 FreeMem 22128 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
752393: Command unknown: AUTH ba8ac784ecdcef62eaa037acb1725fac
752982: SYS : 5.6
768945: SYS : 13
781890: WD : Uptime 13 ConnectFailures 0 FreeMem 20616 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
782507: Command unknown: AUTH a6da2195fcc9e5d70996aeb6c75a15f8
799982: SYS : 5.8
811890: WD : Uptime 14 ConnectFailures 0 FreeMem 22464 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
812195: Command unknown: AUTH 7abc9d54fd76604c212f1e692cda48b3
823228: DS : Temperature: Error! (28-82-df-b5-06-00-00-6a [DS18B20])
832945: SYS : 14
841890: WD : Uptime 14 ConnectFailures 0 FreeMem 22440 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
842370: Command unknown: AUTH 112003aa32cfad8528f0c3b3574781d0
846982: SYS : 5.9
871890: WD : Uptime 15 ConnectFailures 0 FreeMem 22464 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
872576: Command unknown: AUTH 07e2d3610e206634eca663adb6652b9a
893982: SYS : 5.0
896945: SYS : 15
901890: WD : Uptime 15 ConnectFailures 0 FreeMem 22464 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
902276: Command unknown: AUTH dcb9b6d0ffc70a1efc91c1d2d331e7e6
931890: WD : Uptime 16 ConnectFailures 0 FreeMem 22440 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
932487: Command unknown: AUTH 1fe80980ca0acb6db7af8b3e6053c077
Do you really need an 1M build?
As in, does your device only have 1M of flash?
If so, then it is a bit tricky to upgrade as you need to connect via serial to flash a new build.
Just to be sure, you aren't using one of those Sonoff boards and connecting sensors to it which can be touched or make contact with water... right?
Quite a lot of those commercially sold modules or power plugs with an ESP8266 and 1M flash do not have proper isolation from mains power.
So if you solder anything to its internals and make it available on the outside of the enclosure, then you may create a dangerous situation if the unit doesn't have proper isolation.
Just as a rule-of-thumb; If the device can also measure power consumption, then it will for sure NOT be isolated.
It is best to make sure there is no direct connection between GND of the ESP board and any of the mains power pins.
You can try to measure its resistance using a multimeter.
TD-er wrote: ↑01 Aug 2024, 15:19 Do you really need an 1M build?
No water inside. Try a lot of powersupplys.
What flash is better the 4m? Or what do you mean?
I am a dombo from the sesnties, and a windows noob....
Proud to run some eps wit tasmota and a lot with espeasy.. Not an expert
En i try to get the 4.7k and 5 and 3... 5 dallas is a lot, so i think a other ressister to try also not working.
What we're trying to say are a few different things:
1) Be very careful if you have ESP-based units, like those from Sonoff, that are connected directly to 230V mains power!
2) If you have a board with 4MB Flash memory ('NodeMCU v3' suggests you have), then please use a 4M1M build, as that makes it much easier to upgrade ESPEasy, by using the Tools/Update Firmware button via the browser.
And also you should be using a more recent release of ESPEasy, if only to have the hugely improved Dallas sensor support.
3) If anyway possible, please test each Dallas sensor separately, just to make sure each still works as it should. Then later you should be able to again use them in parallel, as intended.
Looking at the results from your log, it's very likely that some of the sensors are damaged.
The pull-up resistor for a single sensor should be around 4k7, having multiple sensors wired together (up to 100 seems to be possible!) that value might need to be a bit lower, but probably not (much) below 2k2. With 5 sensors, the 4k7 value seems fine.
NB: That 'power flow' event, was that caused by a lightning strike at the location of the terrarium? As that would increase the chances of broken, or possibly unreliably working, sensors.
Try a compleet new setup.
Only this one: 4M1M build i cannot find.
I use the webflash, only there are so much builds..
Wat is the best simple for dallas:-)
If you have ESPEasy running on this board/node, then please navigate to the System Info page (blue button "More info" on the first page) and on the system info page, please check near the bottom of the page what size of flash is detected.
If this shows something like this:
then you have a 4 MB flash chip.
If it shows "1024" then you have a 1 MB flash chip.
If you have a board with 4MB of flash, then please flash a "Normal 4M [ESP8266,ESP32,ESP32-S2/S3/C3]" from here: https://td-er.nl/ESPEasy/latest/
N.B. the list is sorted with "LittleFS" builds first and then SPIFFS builds. However for ESP8266 there is only SPIFFS builds.
Flash Chip Real Size: 4096 [kB]
Thanks for all the support!!!
Staerted whole new config.
all sensors renewed.
new bord
1 day.. in the holiday...
Runs like old times..
Only 1 ting not working
Cannot make a backup file. Everytime i run the save button i do get a crash..
I hope i do need a backup for years
new bord
Build: ESP_Easy_mega_20240414_custom_274_ESP8266_4M1M Apr 14 2024
Choose a one... cannot understand al the differents.
Runs with Domoticz, so i am happy...
Just tested the Backup files option on both an ESP32-C2 and ESP8266, and they are working without crashing. Only thing is that Chrome tries to convince me that downloading a .tar file is unsafe, which isn't true (particularly if you know where it's from).
A description of the (many) available builds is in the Readme.md file of the ESPEasy Github repository: https://github.com/letscontrolit/ESPEasy (just scroll down that link)
Installed the same build you used on a unit, and the Tools/Save (Backup isn't available on that release...) option is working without issues, so if you can provide a serial log of the crashes you see, that would be really helpful.
