Max time for deep sleep?
petrho
#1 Post by petrho » 17 Apr 2016, 21:59
I have a NodeMCU 12E and plan to use ESP Easy (now running R101) for deep sleep
I have 3 questions:
1: which is the max time for deep sleep?
2: is deep sleep value the same value as Sensor Delay? And what happened if you have different values in Sensor Delay (config page) compared to Delay in device page?
3: Do I still need to connect GPIO-16 with the RST pin?
Thanks in advance!
ogollemon
Re: Max time for deep sleep?
#2 Post by ogollemon » 20 Apr 2016, 21:15
Hi Petrho,
if you want to use deep sleep, you have to connect 16 with rst.
regards,
ogo
Martinus
#3 Post by Martinus » 21 Apr 2016, 16:03
Max deep sleep is 70 minutes (32 bit uSeconds counter)
In case of deep sleep it should ignore all task specific delays and only use the main delay setting (which specifies the deep sleep time in seconds)
petrho
#4 Post by petrho » 21 Apr 2016, 16:23
When I set 600 sec it will be just 57 minutes
Users browsing this forum: Ahrefs [Bot] and 20 guests
