ESP Easy setup via Serial
yml020
#1 Post by yml020 » 26 Apr 2016, 10:46
Can anyone please give me the syntax of the "IP" command when setting up ESP Easy via the serial interface.
IP Set a static ip adress is the command. I need to set a static IP, with the GateWay and Sub-net mask.
I can set the following some connections are all correct:-
WifiSSID Set the SSID of your homenetwork. "WifiSSID yournetworkname"
WifiKey Set the WPA key of your homenetwork "WifiKey yoursecretkey"
WifiConnect Connect to wifi.
Any help will be appreciated.
Oehoeboeroe
Re: ESP Easy setup via Serial
#2 Post by Oehoeboeroe » 27 Apr 2016, 08:24
ip youripaddress
Like: ip 192.168.1.23
yml020
#3 Post by yml020 » 27 Apr 2016, 09:17
That just plain does not work !?!?!
It says OK, but the "settings" still shows 0.0.0.0
tozett
#4 Post by tozett » 27 Apr 2016, 18:03
simple function looks like working code ..??
https://github.com/ESP8266nu/ESPEasy/bl ... d.ino#L335
yml020
#5 Post by yml020 » 28 Apr 2016, 09:44
Hi.
For some or other reason, on my side, there seems to be a problem.
I only wanted it for emergency setting in case something goes wrong, so it is not too important.
Thank you all for info.
BertB
#6 Post by BertB » 28 Apr 2016, 11:50
Did you issue a reboot after the IP change?
yml020
#7 Post by yml020 » 28 Apr 2016, 15:48
I have just tried now again to change the IP of one of my working devices.
Change IP and reboot. Still stays on the old IP.
tprinslo
#8 Post by tprinslo » 21 May 2016, 16:46
What worked for me is the following
IP xx.xx.xx.xx
save
reboot
Wait for reboot and then confirm with
settings
