ESP Easy setup via Serial
Posted: 26 Apr 2016, 10:46
Can anyone please give me the syntax of the "IP" command when setting up ESP Easy via the serial interface.
IP Set a static ip adress is the command. I need to set a static IP, with the GateWay and Sub-net mask.
I can set the following some connections are all correct:-
WifiSSID Set the SSID of your homenetwork. "WifiSSID yournetworkname"
WifiKey Set the WPA key of your homenetwork "WifiKey yoursecretkey"
WifiConnect Connect to wifi.
Any help will be appreciated.
