Thingspeak Controller not working correctly - Solved
rmtucker
#1 Post by rmtucker » 07 Oct 2015, 13:30
I have two tasks set up in ESPeasy:-
Task1 = Pulse count
Task2 = Temperature
When sending to Thingspeak only Task1 is being received?
I mentioned this in another post about reading the Vdd voltage also.
http://www.esp8266.nu/forum/viewtopic.php?f=4&t=130
I think this is because the two tasks are being sent in quick succession instead of on one line.
Martinus
Re: Thingspeak Controller not working correctly
#2 Post by Martinus » 07 Oct 2015, 13:44
I think you have to set the message delay to 15000.
rmtucker
#3 Post by rmtucker » 07 Oct 2015, 13:54
Ahh Yes missed that in the advanced settings.Thank you!
That does mean though that in a battery powered Sensor,that the whole thing is powered up an extra 15secs per task.
That will flatten the batteries very quickly.
It normally only takes around 6secs to power up and send the data then go back too sleep,So now that will be 21secs Minimum.?
