Sd card support
romix
Sd card support
#1 Post by romix » 06 May 2016, 10:58
I am using ESPeasy on Wemos d1 mini modules. There is a neat sd-card shield for this module. How hard is it to support piping data to a file on the sd card, to be read/controlled via the web?
See wemos.cc for the d1 mini and its shields.
romix
Re: Sd card support
#2 Post by romix » 06 May 2016, 19:36
A bit more background.
A client of mine wants to store Smart Meter readings on an SD card, because he does not have a server running to collect the data (trying to persuade him to adopt Domoticz).
Adding DS card support for ser2net is easy (adding a couple of lines based on a define in espeasy.ino and including the libs for sd and spi does the trick.
#if FEATURE_SD
if (!SD.begin(chipSelect)) {
Serial.println("initialization failed!");
} else {Serial.println("initialization done.");}
File dataFile = SD.open("DATA.TXT", FILE_WRITE);
if (dataFile) {
Serial.print("Writing to DATA.TXT...");
dataFile.write(net_buf, bytes_read);
dataFile.close();
#endif
Reading the data is also easy adding
#if FEATURE_SD
WebServer.on("/downloadSD", handle_SDdownload);
#endif
and
#if FEATURE_SD
// Ronald experimental SD card support
// Web Interface download page for SD card
void handle_SDdownload()
if (!isLoggedIn()) return;
File dataFile = SD.open("DATA.TXT");
if (dataFile) {
WebServer.sendHeader("Content-Disposition", "attachment; filename=DATA.TXT");
Serial.println("data.txt:");
// read from the file until there's nothing else in it:
WebServer.streamFile(dataFile, "application/octet-stream");
// close the file:
dataFile.close();
} else {
// if the file didn't open, print an error:
Serial.println("error opening data.txt on SD card");
return;
#endif
does the trick. Off course this a dirty hack. It does not really integrate in the architecture. Would adding a controller plugin 'SD card' _C009 be more appropriate? Do all plug-ins correctly use the controllers? Any ideas on how to properly add support for SD (if at all desirable)?
