i just created a switch (with an relay) which should work as a button.
For this case, i created a rule:
On switch1#Switch1 do
gpio,5,1
timerSet,1,1
On Rules#Timer=1 do
gpio,5,0
So if Switch1 has the command "ON", after a secound it should be "OFF"
Unfortunately 1 secound is in REAL ~4 secounds. So it seems that it has an delay for some reasons.
Any ideas about that problem ?
timerSet rule
Re: timerSet rule
It is not a problem, it is a featureAny ideas about that problem ?
It is a known fact that there can be a substantial delay over WiFi , you have to live with it.
I have it too when I use rules, a few seconds is normal.
