Can not flash twice ?
Posted: 11 Jul 2016, 14:33
I flashed Easy Esp RT108 on a Wemos D1 Mini. All as correct and I could use it with any sensors and domoticz. After Playing with it all the day I switched the power off.
This morning I wanted to try news things...
The problem is that I can not access my Wemos in my webbrowser... the IP adress is not responding !
I wanted to flash once again to erease all and go on with a clean setup...
Flashing seems to be Ok but I never have the ESP0 access point to setup my Wemos ....
Then : I can not access and even not flash ... is it bricked ? ... How can I recover ?
Thank you
Thank you
