Can not flash twice ?
phil77560
#1 Post by phil77560 » 11 Jul 2016, 14:33
I flashed Easy Esp RT108 on a Wemos D1 Mini. All as correct and I could use it with any sensors and domoticz. After Playing with it all the day I switched the power off.
This morning I wanted to try news things...
The problem is that I can not access my Wemos in my webbrowser... the IP adress is not responding !
I wanted to flash once again to erease all and go on with a clean setup...
Flashing seems to be Ok but I never have the ESP0 access point to setup my Wemos ....
Then : I can not access and even not flash ... is it bricked ? ... How can I recover ?
Thank you
rkoppen
Re: Can not flash twice ?
#2 Post by rkoppen » 11 Jul 2016, 15:08
Maybe a stupid question but did you arrange for a fixed ip address ?
Did it end up in a different IP because it shut down ?
phil77560
#3 Post by phil77560 » 11 Jul 2016, 16:56
rkoppen wrote:Maybe a stupid question but did you arrange for a fixed ip address ?
No more IP... I did a IPscan... that's why I wanted to flash once more
rkoppen
#4 Post by rkoppen » 12 Jul 2016, 08:37
phil77560
#5 Post by phil77560 » 12 Jul 2016, 13:14
I Finally used a serial command ...
I used arduino IDE serial monitor and used "Settings" command ... I could read the configuration, the IP adress and set another one...A no given by DHCP !
Thank you for your help ...
