I flashed Easy Esp RT108 on a Wemos D1 Mini. All as correct and I could use it with any sensors and domoticz. After Playing with it all the day I switched the power off.
This morning I wanted to try news things...
The problem is that I can not access my Wemos in my webbrowser... the IP adress is not responding !
I wanted to flash once again to erease all and go on with a clean setup...
Flashing seems to be Ok but I never have the ESP0 access point to setup my Wemos ....
Then : I can not access and even not flash ... is it bricked ? ... How can I recover ?
Thank you
Can not flash twice ?
Re: Can not flash twice ?
Maybe a stupid question but did you arrange for a fixed ip address ?
Did it end up in a different IP because it shut down ?
No more IP... I did a IPscan... that's why I wanted to flash once morerkoppen wrote:Maybe a stupid question but did you arrange for a fixed ip address ?
I Finally used a serial command ...
I used arduino IDE serial monitor and used "Settings" command ... I could read the configuration, the IP adress and set another one...A no given by DHCP !
Thank you for your help ...
Users browsing this forum: Ahrefs [Bot] and 10 guests
