Basic authentication in generic http
marcfon
#1 Post by marcfon » 17 Sep 2016, 15:03
Is there a way to do basic url authentication with the generic http protocol (http://user:pass@node/data). The Domoticz http protocol has this feature.
Update:
Found it. You need to change 2 lines in _C008.ino, recompile and upload the new binary.
        Protocol[protocolCount].usesAccount = true;
        Protocol[protocolCount].usesPassword = true;
Update 2:
There are actually 2 more edits that need to be done in _C008.ino.
Add this section to the very top of the HTTPSend() method.
  // START Borrowed from _C001
  String authHeader = "";
  if ((SecuritySettings.ControllerUser[0] != 0) && (SecuritySettings.ControllerPassword[0] != 0))
    base64 encoder;
    String auth = SecuritySettings.ControllerUser;
    auth += ":";
    auth += SecuritySettings.ControllerPassword;
    authHeader = "Authorization: Basic " + encoder.encode(auth) + " \r\n";
  // END Borrowed from _C001
And replace
  client.print(String("GET ") + url + " HTTP/1.1\r\n" +
               "Host: " + hostName + "\r\n" +
               "Connection: close\r\n\r\n");
with this
               "Host: " + host + "\r\n" + authHeader +
