Release 43 is available!
- New Device: MiLight WW/CW remote & Bulbs
- New Device: WH3 temperature sensors
- New Device: Alecto 1300 Wireless Plant Monitor
- New Device: Unitec W235 Climate sensor
- New Device: Jula / Marquant 943134 temperature sensor
- New Device: Inovalley SM200
- New Device: DC250 motor controller
- New Device: Maplin Weather Station N96GY, Fine Offset WH1080, Fine Offset WH1081, Watson W-8681,
Digitech XC0348 Weather Station, PCE-FWS 20, Elecsa AstroTouch 6975, Froggit WH1080
- New Device: Loh Electronics 02812 Temperature and Humidity sensor
- New Device: Excelvan weather station
- New Device: Master Electrician RC-012-1-TR-009
- New Device: Home Confort STHI 100 temperature/humidity sensor
- New Device: Ditec Garage Door remote control
- New Device: Acurite 609TXC (alternative protocol)
- New Device: WS7000-27, WS7000-28 Thermometer
- New Device: WS7000-25 Thermo/Humidity, WS7000-22 Thermo/Humidity
- New Device: WS7000-19 Brightness Luxmeter
- New Device: Holtek HT6P20 (and compatible) Door, Window and PIR sensors (Thanks: Douglas Gazineu)
- New Device: Ambient Weather / Frogit F007TH
- New Device: Ambient Weather / Frogit F007PF
- New Device: SelectPower switchset
- New Device: Profile led dasegno
- New Device: KERUI D026 Door Window Sensor
- New Device: LaCrosse TXT141-BV2
- New Device: Baldr B0317
- New Device: Atlantic MC-335 PIR
- New Device: RTS sensor protocol / Soliris
- New Device: RTS Extended protocol / Eolis 3D
- Fixed: Removed slash (/) from device names
- Fixed: Removed RTS and other debug data
- Fixed: Avidsen switch issue
- Fixed: Avidsen temperature data detection
- Fixed: Blyss & Avidsen pairing working correctly
- Fixed: AB440R signal detection
- Fixed: Chuango signal detection
- Fixed: Improved Promax detection
- Fixed: Additional check to make sure Milight send is not used when Milight support is disabled
- Fixed: WS2500-19 now correctly reporting Lux value
- Fixed: Milight RGBW Remote and WW/CW (Dual) Remote Control operating simultaneously with RGBW
- Fixed: Livolo On/Off state
- Fixed: Brel timing
- Fixed: Novatys detection
- Fixed: AMST606 detection issues
- Fixed: SelectRemote doorbell retransmission
- Fixed: Byron SX doorbell retransmissions
- Fixed: Byron SX doorbell recognition
- Fixed: Further improved the RF Environment Optimization System
- Fixed: improved the detection of Acurite devices
- Fixed: improved the detection of Cresta devices
- Fixed: improved the detection of Atlantic devices
- Added: NRF24L01 hardware detection, activating MiLight without NRF will result in MiLight being disabled
- Added: Smarthome YC-4000B protocol variant
- Added: New Brel protocol version
- Added: WS7000 protocol variant
Available on the download page at:
www.nemcon.nl/blog2
Re: Release 43 is available!
Great work (again), thanks
what about / some news about the mysensors integration ?
test implementation was not working stable yet. will take some more time.
We do have working Philips Living Colors and Ikea Ansluta, support for this is coming up first.
