Espeasy R140
smagghe
Espeasy R140
#1 Post by smagghe » 19 Oct 2016, 21:12
I try to use the NTP time and i've a little question ? why when i set DST, the time switch to 12 hours mode from 24 hours mode ?
I need to automaticly set the dst (with formula) so i need the 24 hours mode.
Whith old version...Build 103 (a very old version) there's no problem.
Thank's a lot for your help
Gabriel
Eisbaeeer
Re: Espeasy R140
#2 Post by Eisbaeeer » 21 Oct 2016, 23:43
Hi.
This will be nice. I will use the ESP Easy to sync my Atmega with the NTP time. The Atmega time runs as 24h clock. The sync should work with the UART. I´m get running it with the rules section and output with %systime% value and timer event. I parse it in the atmega to get the time.
This project ist great and Im wondering, why you don´t use the UART for more features?
I get no working interact with the UART and the firmware. I only can receive the output from ESPEasy, but can not send any command to the module? What do I wrong?
The howto describe, that you can send commands through UART?
It will be nice, if we can transmitt an NTP request (configured through the web) through the UART and get the time through UART.
Many thanks to all programmers of this project!
Eisbaeeer
P.S.: Don´t hesitate to contact me ;-)
