MQTT Domoticz improvement
Mazzokun
#1 Post by Mazzokun » 02 Nov 2016, 09:35
Hi all! I'm new with ESP. I flashed 3 Sonoff switch with ESP EASY and I'm using MQTT to control them with virtual switch in Domoticz.
Works well but if I put on switch, then pull off AC power from Esp, pull on AC power to ESP, and last turn back into domoticz I see the light on.. but the real lamp is off..
Is there a way to send the status of the switch to domoticz at boot time? Or a way to send the status of the switch to domoticz every X time?
Because if i Use HTTP Domoticz setting there is an option to send to domoticz the status of the switch but Http requests are very slow compared to MQTT.
Thank you, I know I'm a NOOB :oops:
Users browsing this forum: Anthropic Claude Bot [bot], Bing [Bot] and 9 guests
