Hello everyone
I would like to use a easyesp plugin but I can't find a 'how to'?
Do I have to merge the plugin ino with the easyesp.ino?
Czn some one tell me how to use plug-ins?
Thanks guys
How to use plugin?
Re: How to use plugin?
just copy .ino file to your espeasy directory and compile it.. upload, and in devices you'll find that plugin...
Hi, i have a problem with compile...
Somebody help me?
I need the gas sensor (MQ-2) in my EspEasy (i have the ESP-01) - https://github.com/ESP8266nu/ESPEasy/pull/96/files
and when i compile in Arduino IDE i have a bugs... Somebody have a "howto?"
i do everything like this tutorial : (http://www.letscontrolit.com/wiki/index ... are_Upload) , but is not working... Somebody help? or compile for me ?
Btw. Sorry for my english
EDIT : Its WORKING - Problem Solved !
Somebody help me?
Describe here how it solved
How did you connect mq2 sensor? are you using it as a switch or able to measure analog value? Because esp-01 does not have T-Out exposed.ppaciek wrote:Hi, i have a problem with compile...
Somebody help me?
