Problem with Wifi Settings
davilico05
#1 Post by davilico05 » 05 Dec 2016, 14:22
Hi, I configurated the wifi settings. I introduced Bad IP and Subnet. Not possible to acces web and serial port show parametrers but I send command noting happend.
Help!
NightBird
Re: Problem with Wifi Settings
#2 Post by NightBird » 05 Dec 2016, 16:41
if serial access is still available, you can try to factory reset your ESP.
Just type 'Reset' (without quotes) followed by CTRL-J to put the ESP back to factory settings.
It will activate the AP mode (ESP_0 with password configesp) and allow access to IP 192.168.4.1
Another solution is to reflash the firmware...
ESPEasy running on ESP-12F self-made modules (with various sensors) and talking to Domoticz (hosted on RPi2)
timsson
#3 Post by timsson » 05 Dec 2016, 18:22
connect Tx+Rx + off/on -> reset
Drum
#4 Post by Drum » 07 Dec 2016, 12:34
NightBird wrote:Hi,
Fortunately for most of us Re-flashing does not clear the settings. TX-RX trick from timsson will clear the settings.
