Showing BSSID in Network Assistant
Hi, is it possible to show the BSSID or the RSSI value of avail Hotspots in Network setup? I have 3 accesspoints with same SSID in my house and it would be great to connect the closest one.
Re: Showing BSSID in Network Assistant
Is it further possible to connect to the closest Accesspoint automatically? In attached RSSI chart you see 4 devices. I have 2 active accesspoints with same SSID active. One Accesspoint had a reboot last night. All 4 ESP devices connect to the other AP - thats fine. But after reboot the closer AP is avail again. Unfortunately the devices stay on the bad connection although a better connection is avail on same SSID
- IMG_3932.PNG (125.9 KiB) Viewed 2442 times
Users browsing this forum: Bing [Bot] and 13 guests
