TimerStop Rule
maluko
TimerStop Rule
#1 Post by maluko » 18 Dec 2016, 21:37
hi guys
thanks for the work that all have done.
i am thinking about this rules command "TimerStop" that dont are implemmented, i wonder that was a good idea to save memory when its is runing the timerset command.
So i will give a example:
i have domoticz to send http command to start event on esp "http://xx.xx.xx.xx/control?cmd=event,rele10", and on esp rules have:
on rele10 do
 MCPGPIO,1,0 // Open valve
 timerSet 1,1800
on Rules#Timer=1 do
 MCPGPIO,1,1 // close valve
so mean that the rule will run 30 min to close the relay, but this is only for security because on domoticz i only have timer for 5,10,15, or 20 min, dont want when domoticz fails have the irrigation run for internity.
resume: domoticz open and close the relay but esp rule timer continues run after close.
what i want say with this?
with this command we could do this:
on rele10 do
 MCPGPIO,1,0  //open valve
 timerSet 1,1800
on Rules#Timer=1 do
 MCPGPIO,1,1 //close valve
on rele10#Switch=1
  timerStop 1 //will stop timer  if valve are close before 1800s
I have 8 reles running one after the other, but it is causing some reboot so I think it will exceed the RULES_TIMER_MAX or SYSTEM_TIMER_MAX.
thanks and merry christmas
toffel969
Re: TimerStop Rule
#2 Post by toffel969 » 07 Jan 2017, 22:42
If you can live with 1 second delay you could do
on rele10 do
 timerSet 1,1800
on Rules#Timer=1 do
on rele10#Switch=1
  timerSet 1,1 //will set the timer to 1 second ~"stop" the timer (maybe even 0 works, i never tried)
concerning your reboots. Are you powering all 8 relays through the 3,3 V of your ESP device (nodeMcu?,Wemos mini ? ).
If yes you might just overload the power regulator (usually switching the relays is fine, but 8 Relays + the Wifi TX burst are too much). You can try a nice capacitor over 3,3V and GND (in order to stabilize voltage for TX bursts) or try to supply the relay with a seperate 3,3V power regulator (just tie GNDs together).
maluko
Re: TimerStop Rule
#3 Post by maluko » 07 Jan 2017, 23:10
thanks, i think that all reboot was from breadboard so i will do a pcb to try because now its more stable.
the relay board is runing with power from 24vac- 5vdc converter and not by esp12f.(3.3V), have too on pcb for future propose the capacitor field.
and at this moment i have this rules:
On System#Boot do
 MCPGPIO,1,1
 delay 10
 MCPGPIO,2,1
 delay 10
 MCPGPIO,3,1
 delay 10
 MCPGPIO,4,1
 delay 10
MCPGPIO,5,1
 delay 10
 MCPGPIO,6,1
 delay 10
 MCPGPIO,7,1
 delay 10
 MCPGPIO,8,1
on rele10 do
 MCPGPIO,1,0
 timerSet 1,1800
on Rules#Timer=1 do
 MCPGPIO,1,1
on rele20 do
 MCPGPIO,2,0
 timerSet 2,1800
on Rules#Timer=2 do
 MCPGPIO,2,1
on rele30 do
 MCPGPIO,3,0
 timerSet 3,1800
on Rules#Timer=3 do
 MCPGPIO,3,1
on rele40 do
 MCPGPIO,4,0
 timerSet 4,1800
on Rules#Timer=4 do
 MCPGPIO,4,1
on rele50 do
 MCPGPIO,5,0
 timerSet 5,1800
on Rules#Timer=5 do
 MCPGPIO,5,1
on rele60 do
 MCPGPIO,6,0
 timerSet 6,1800
on Rules#Timer=6 do
 MCPGPIO,6,1
on rele70 do
 MCPGPIO,7,0
 timerSet 7,1800
on Rules#Timer=7 do
 MCPGPIO,7,1
on rele80 do
 MCPGPIO,8,0
 timerSet 8,1800
on Rules#Timer=8 do
 MCPGPIO,8,1
On botao1#Switch=1 do
 if [rele10#Switch]=1
  event rele10
  MCPGPIO,1,1
On botao2#Switch=1 do
 if [rele20#Switch]=1
  event rele20
  MCPGPIO,2,1
On botao3#Switch=1 do
 if [rele30#Switch]=1
  event rele30
  MCPGPIO,3,1
On botao4#Switch=1 do
 if [rele40#Switch]=1
  event rele40
  MCPGPIO,4,1
On botao5#Switch=1 do
 if [rele50#Switch]=1
  event rele50
  MCPGPIO,5,1
On botao6#Switch=1 do
 if [rele60#Switch]=1
  event rele60
  MCPGPIO,6,1
On botao7#Switch=1 do
 if [rele70#Switch]=1
  event rele70
  MCPGPIO,7,1
On botao8#Switch=1 do
 if [rele80#Switch]=1
  event rele80
  MCPGPIO,8,1
maluko
Re: TimerStop Rule
#4 Post by maluko » 07 Jan 2017, 23:59
i tried what you said and work fine, even with 0s, it stop the first time command. so this are a little modification that can be done on my rules, only with a little problem Current size: 2133 characters (Max 2048) :D
On System#Boot do
 MCPGPIO,1,1
 delay 10
 MCPGPIO,2,1
 delay 10
 MCPGPIO,3,1
 delay 10
 MCPGPIO,4,1
 delay 10
MCPGPIO,5,1
 delay 10
 MCPGPIO,6,1
 delay 10
 MCPGPIO,7,1
 delay 10
 MCPGPIO,8,1
on rele10 do
 MCPGPIO,1,0
 timerSet 1,1800
on Rules#Timer=1 do
 MCPGPIO,1,1
on rele10#Switch=1 do
 timerSet 1,0
on rele20 do
 MCPGPIO,2,0
 timerSet 2,1800
on Rules#Timer=2 do
 MCPGPIO,2,1
on rele20#Switch=1 do
 timerSet 2,0
on rele30 do
 MCPGPIO,3,0
 timerSet 3,1800
on Rules#Timer=3 do
 MCPGPIO,3,1
on rele30#Switch=1 do
 timerSet 3,0
on rele40 do
 MCPGPIO,4,0
 timerSet 4,1800
on Rules#Timer=4 do
 MCPGPIO,4,1
on rele40#Switch=1 do
 timerSet 4,0
on rele50 do
 MCPGPIO,5,0
 timerSet 5,1800
on Rules#Timer=5 do
 MCPGPIO,5,1
on rele50#Switch=1 do
 timerSet 5,0
on rele60 do
 MCPGPIO,6,0
 timerSet 6,1800
on Rules#Timer=6 do
 MCPGPIO,6,1
on rele60#Switch=1 do
 timerSet 6,0
on rele70 do
 MCPGPIO,7,0
 timerSet 7,1800
on Rules#Timer=7 do
 MCPGPIO,7,1
on rele70#Switch=1 do
 timerSet 7,0
on rele80 do
 MCPGPIO,8,0
 timerSet 8,1800
on Rules#Timer=8 do
 MCPGPIO,8,1
on rele80#Switch=1 do
 timerSet 8,0
  event rele10
  timerSet 1,0
  event rele20
  timerSet 2,0
  event rele30
  timerSet 3,0
  event rele40
  timerSet 4,0
  event rele50
  timerSet 5,0
  event rele60
  timerSet 6,0
  event rele70
  timerSet 7,0
  event rele80
  timerSet 8,0
toffel969
Re: TimerStop Rule
#5 Post by toffel969 » 08 Jan 2017, 20:28
[quote="maluko"]thanks, i think that all reboot was from breadboard so i will do a pcb to try because now its more stable.
Be careful with the 5V supply to the relay board. I found unstable behaviour when using a nodemcu with a 5V power supply, connecting the Vcc of the Relayboard straigt to a Vin (=5v) --> I dont remeber exactly what happened, i just made mental note that Vcc must be equal to TTL-level (=3,3v), and that I had to rewire a node already in the field
maluko
Re: TimerStop Rule
#6 Post by maluko » 08 Jan 2017, 21:18
toffel969 wrote:
maluko wrote:thanks, i think that all reboot was from breadboard so i will do a pcb to try because now its more stable.
isnt work with 5v, i have a converter to 3.3v only for esp and sensors.
Users browsing this forum: Bing [Bot] and 6 guests
