problem with nodemcu devkit 1.0 and r39
vectah
#1 Post by vectah » 08 Nov 2015, 22:11
I'm using Nodemcu devkit 1.0 (esp12e). When I flash version r20 everything works fine, but when I upload r39 I'm getting this:
PID:0
Version:0
RESET: Reboot count: 0
ctx: cont
sp: 3ffecae0 end: 3ffecd60 offset: 01b0
>>>stack>>>
3ffecc90:  00000002 4000410f 3ffeccd0 00000121
3ffecca0:  3fffc718 40004a3c 0000011b 0011b000
3ffeccb0:  3fffc718 40101dcc 0000011b 40219c2c
3ffeccc0:  0000011b 40208256 0000011a 40208283
3ffeccd0:  3fff5410 00000018 00000018 40218f28
3ffecce0:  3f0155aa 00000014 402554d1 3ffecd8c
3ffeccf0:  3ffea0dc 00000000 3ffecdc0 40208330
3ffecd00:  3ffea001 3ffecd8c 402026d0 3ffebd40
3ffecd10:  40201bca 000003e8 000003e8 3ffecd8c
3ffecd20:  3ffea0dc 3ffea9f4 3ffecdc0 4020af58
3ffecd30:  00000000 00000000 00000000 00000000
3ffecd40:  3fffdc20 00000000 3ffecd84 40202743
3ffecd50:  00000000 00000000 3ffebd40 40100374
<<<stack<<<
 ets Jan  8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 1264, room 16
tail 0
chksum 0x42
csum 0x42
~ld
ŞU
PID:0
Version:0
RESET: Reboot count: 1
ctx: cont
>>>stack>>>
3ffecce0:  3f0255aa 00000014 402554d1 3ffecd8c
3ffecd00:  3ffea002 3ffecd8c 402026d0 3ffebd40
<<<stack<<<
tail 0
chksum 0x42
csum 0x42
~ld
ŞU
PID:0
Version:0
RESET: Reboot count: 2
ctx: cont
>>>stack>>>
3ffecce0:  3f0355aa 00000014 402554d1 3ffecd8c
3ffecd00:  3ffea003 3ffecd8c 402026d0 3ffebd40
<<<stack<<<
tail 0
chksum 0x42
csum 0x42
~ld
ŞU
PID:0
Version:0
RESET: Reboot count: 3
ctx: cont
>>>stack>>>
3ffecce0:  3f0455aa 00000014 402554d1 3ffecd8c
3ffecd00:  3ffea004 3ffecd8c 402026d0 3ffebd40
<<<stack<<<
tail 0
chksum 0x42
csum 0x42
~ld
ŞU
PID:0
Version:0
RESET: Reboot count: 4
RESET: To many reset attempts
Entered Rescue mode!
I tried to erase flash with easyesptool.ino, I tried to reflash nodemcu lua firmware, I tried to flash r20 and then flash easy esp r39 but still get the same results.
I would really like to get it to work because I use SI7021 sensors which are not included in r20 release.
BertB
Re: problem with nodemcu devkit 1.0 and r39
#2 Post by BertB » 08 Nov 2015, 22:29
I do not know why this happens, but I had the same issue today.
Did you hit the reset button?
I solved it by first flashing 20, then 30 then 39. That worked. In 30 I also entered network address and devices.
vectah
#4 Post by vectah » 08 Nov 2015, 23:47
I figured out how to download r30 finally :) But thank you for the link.
INIT : Booting Build nr:39
WIFI : Connecting...
WIFI : No SSID!
INIT : I2C
INIT : Boot OK
INIT : Normal boot
Updating from r20 to r30 to r39 worked like a charm! Thanks for the suggestion. Does anyone have an idea why r39 doesn't work when uploaded to brand new nodemcu 1.0 board? Is there a way to edit the code so I could flash r39 without having to upgrade to 2 previous versions of easy esp?
rmtucker
#5 Post by rmtucker » 09 Nov 2015, 10:29
I had the same problem here:-
http://www.esp8266.nu/forum/viewtopic.php?f=4&t=184
Seems to be a problem for just a couple of people not sure why?
But i now just do as you have and install v30 then v38.
rmeijs
#6 Post by rmeijs » 10 Nov 2015, 21:19
Unfortunately I had the same problem with R39 on brand new ModeMcu 1.0 (but the upgrade path via R20 & R30 also worked for me).
